  4. Turn off switch
Turn off switch
4 Posts 3 Posters 1.0k Views
  • VcelickaV
    VcelickaV
    Vcelicka
    Hi guys, iam not a eletrician but i was wondering if i could change the turn off switch to button
    I dont know if its possible , but i just wanted to ask if anyone haves it .....
    I thing it would look a lot cleaner and im more in love with them from my old bike
      Yeah it should be possible.
      What type of button are you looking for? Momentary button or a toggle button?
      Toggle button would be simple, momentary button would probably be possible but a bit faffy.
      You effectively bring the voltage to the ground state, but you'd need to wait for the engine to stop spinning before letting go.
      VcelickaV 1 Reply Last reply
        VcelickaV
        VcelickaV
        Vcelicka
        Like i said im not a electrician 😄
        I want same button like normal dirt bikes have. ( You hold it to stop and then relese )
        I already bought one but it closes the circuit only when pressed ....... 😕
        can i somehow change it to do when relesed = i can start the bike when hold = bike stops running
        Thx for the reply
        • VcelickaV Vcelicka
          Thx for the reply
          The engine stops when the connection is made, ignition is earthed. I don’t understand what your problem is?
          If you disconnect the kill switch the bike will still run…
          If you disconnect the ignition key block connector the bike will run but have no lights…
          Just fit the button and try it…
