WHERE Do i find a kickstart
I have gotten a yamaha dt125re engine and i want to put a kick start on it bc it has the spot for it but not the mechanism i would only need the mechanism and then the lever ill get somewhere else but i cant find anything that would fit it (the engine is probably 2005-2008 or something)
@RikuRo Try some of the DTR Facebook groups, doing this to the DT125Re is quite a popular modification and some of the sellers will supply you a kit with everything you need.
