  4. Sealing crank cases
Sealing crank cases
4 Posts 3 Posters 1.0k Views
  • S Offline
    I’ve never used silicone RTV to seal the cases before. What is the best way to apply it? Should I use a bead (if so what size) or dab it on lightly and evenly by hand (with gloves)
    I proper worry about the excess beading out into the crank case and gearbox. I’ve taken one apart that was awful…
    Any advice is appreciated 🐾
      The last time I did crank cases on my DTR I used Yamabond and used a thin paint brush to apply it.
      • R Online
        R Online
        Rallyfinnen
        I dab on a very thin layer, and it has always sealed well. I put so little that there is almost nothing protruding after putting the halves together. I use the grey Athena sealant.
        • S Offline
          Less is more then 🙂 cheers guys. It’s the reason I used hylomar red before, it’s easy to apply thin and evenly…
          I’ll get out the black mechanic gloves and dab on some RTV…
