  4. Carb Diagram
Carb Diagram
6 Posts 3 Posters 3.7k Views
  • RYUU67R
    RYUU67R
    RYUU67
    Hi, anyone have a link to a 125r 1997 carb diagram...hopefully showing hoses ~ all hoses on mine have been removed and i'm buggered if i can figure out what goes where 😕
    Massive thank you if anyone can.....👍
      There shouldn't be anything that will baffle you to be honest.
      The one going into the float chamber is for fuel.
      The two going into the carburettor are carb warmers, not required.
      The rest are overflow.
      RYUU67R 1 Reply Last reply
        RYUU67R
        RYUU67R
        RYUU67
        @Calum Thanks for reply / info....fuel in i think i've got.
        Trying to figure which are warmers and which are overflow.
        And, if i block the warmers.....where do these hoses come from, will i have to block that too ?
        Easily confused mate.....😖
        • RYUU67R RYUU67
          @RYUU67 The original loop goes from thermostat cylinder head, to the offside of the carb. Out the opposite side into the nearside cylinder head.
          To block the carb warmers just loop from the thermostat to the head. Or just place bolts into the head instead of the hoses.
          The carb warmers face the cylinder head. The overflow will face the ground, the fuel line face up.
          • RYUU67R RYUU67
            @RYUU67 This one any good to ya bud???
            https://www.fowlersparts.co.uk/parts/4147642/dt125r-3rm9-1997-030-b/carburettor
            You can save the pic as a png. or jpg and then blow it up for a better look!!! 😉
              RYUU67R
              RYUU67R
              RYUU67
              @CYBER-NINJA Thank you mate, appreciated.....forgot about them....now just to figure out where the pipes from the carb connect to....
              Joys of buying a bike that's been "fixed" by previous owner....
