  4. head nut size
head nut size
8 Posts 2 Posters 2.0k Views
  • britshgigoloB Offline
    britshgigolo
    does and body know what size the head nuts are i know there crown nuts but need to know the size as need to order a set
      M8 I believe
        I also think they need ti be if the correct tensile strength
          britshgigolo
          yes ty calum was told stainless m8 crown nuts and washers are what i need think i have found the nuts i need just got to double check the washer thikness
            So I run Stainless Steel Domed nuts and haven't had any issues.
            However, I am aware that Stainless doesn't like to be tightened or stressed like iron. So you just got to keep an eye out for it,#
            But I've never had any problems,.
              britshgigolo
              so do i not touqe them down as hard as standard nuts
                I think it's that they don't stretch like cast iron bolts so you risk damaging the threads.
                As said, never had any problems just giving you as much information as possible.
                  britshgigolo
                  ok ty calum for all the helpfull infomation its a great help
