  3. Carburetor
  4. dt125r carb
dt125r carb
8 Posts 4 Posters 4.1k Views 1 Watching
  • D Offline
    dtr mkd
    hi guys. on my bike bought from switzerland there is a round slide carb. is that carb any good or need to change to flat slide carb. and what is the right one for the bike.
    thanks
      Old models ran an inferior roumd slide carb. Flat slides.are much more performent.
      • D Offline
        dtr mkd
        which carb do i need to perform better
        • D dtr mkd
          @dtr-mkd As said, the flatslide carb is better.
          D 1 Reply Last reply
            dtr mkd
            @Calum thanks calum but which model of flat slide carb and what jetting for standard
            • D dtr mkd
              @dtr-mkd I can't remember, but all dtre dtx ran the flatslides.
              • DartyD Offline
                DartyD Offline
                wrote on last edited by Darty
                @dtr-mkd Pre 1991' or so, run a Mikuni VM26ss which is a roundslide design.
                After that all DTR/RE/X models use a Yamaha Mikuni TM28ss - Flatslide.
                The VM26 is restricting, but good for low end torque, problem with roundslide carbs is that the design disrupts air flow considerably which slows the intake down.
                For a standard DTR, look for a Mikuni TM30ss, used on the Yamaha WR200. probably the perfect carb upgrade for a 125R.
                • AndyYamA Offline
                  AndyYamA Offline
                  AndyYam
                  You can also try a Delorto VHSA32 which is a 32mm carb used on the TZR 4DL which shares the same engine as the DT125R.
                  Only putting it out there, if it were me, I'd go for a tm28ss which is standard on DT125R from 1991 as Darty says.
                  The jetting changed in around 1996 as well but that will depend on the conditions of where you ride so you'll have to experiment with that.
