  3. Off Topic
  4. Dtr125 rear suspension bush
9 Posts 5 Posters 3.8k Views 1 Watching
  • A Offline
    A Offline
    Ads123
    Hi all I'm having trouble coming across a rear suspension bush for my dtr125... I'm aware that Yamaha have stopped making them, but just woundering if anyone has the same issue and could point me in the right direction on where to get it from. Thanks in advance 🙂
    N 1 Reply Last reply
    • A Ads123
      @Ads123 Have you tried any of these suppliers dude???
      https://dt125r.co.uk/topic/562/parts-suppliers-database
      A 1 Reply Last reply
        Which bush is this bud?
        • N NINJA
          A Offline
          A Offline
          Ads123
          @CYBER-NINJA no I will have a check now cheers 🙂
            A Offline
            A Offline
            Ads123
            @Calum the rear bottom suspension bush I know Yamaha have stopped making them now I read something up on it not 100% sure on it tbh
              Still not clear. But I recently rebuilt my Suspension and did not have any problems. I went to Simply bearings
              • F Offline
                F Offline
                Do you mean the hard plastic bushes? I bought some from fowlers late last year. If you can't get hold of any I'd have some made in brass
                • C Offline
                  C Offline
                  callusdw
                  Hi, guys. I also require the bottom bush for a rear shock absorber on a 98 DT 125. It is made up of 2 collars and some kind of bush in the middle.
                  @Calum Did you rebuild the bottom bush? Was it set out the same way?
                  I've trawled the links in the parts database with no luck. Seems Yamaha have stopped making the collars.
                  thanks
                  Dean
                  • C callusdw
                    thanks
                    Dean
                    @callusdw I didn't mate. I took the spring off and had it coated. But everything else was sound.
