  3. Top End
  4. Pv turned when running?
5 Posts 2 Posters 2.0k Views
  • declanD Offline
    0_1495125490708_IMG_1100.JPG is this normal does it when idling
      Yeah it closes on idle...
      When it lines up with the whole that means it's open.
        @Calum thanks bud!
          You can tell cause when you power cycle the ignition, after the engine has been running the powervalve does an extra turn. But when you turn it on and off without starting the engine, it won't do that.
            @Calum appreciate the help as usual 👍👍
