How do I remove rev limiter
Remind me of the year?
The 2001-2004 ones simply cannot be done.
Get yourself a Zeeltronic and the rev limiter cap is 20k
@declan Oh, even on a restricted CDI that's low. Sounds like powervalve, or the rev counters faulty, or the engine is on its way out.
Most likely powervalve.
If I Recall Correctly
@calum pv is adjusted donโt think this is the issue since I actually hear the rev limiter if I miss a gear
@declan I would pin the powervalve in the open position and max it outnin 3rd to ensure it isn't the valve.
With your input, this post could be even better ๐
