  4. How do I remove rev limiter
13 Posts 3 Posters 2.2k Views
  • declanD
    Iโ€™ve followed every tutorial under the sun and just canโ€™t find out how I do mine
      Remind me of the year?
      The 2001-2004 ones simply cannot be done.
      Get yourself a Zeeltronic and the rev limiter cap is 20k
        @calum 1990 but it could have a newer loom who knows
          What's the code on the CDI?
          1990's shouldn't be restricted IIRC
            @calum iirc? And I will get that later bud only revs to around 8.9k
              @declan Oh, even on a restricted CDI that's low. Sounds like powervalve, or the rev counters faulty, or the engine is on its way out.
              Most likely powervalve.
              If I Recall Correctly
                @calum itโ€™s pissible and no the engine is pretty fresh
                  @declan Check the powervalve then bud.
                    @calum pv is adjusted donโ€™t think this is the issue since I actually hear the rev limiter if I miss a gear
                      @declan I would pin the powervalve in the open position and max it outnin 3rd to ensure it isn't the valve.
                      • terry.tzT
                        terry.tzT
                        terry.tz
                        i have the same problem but no desire to solve it yet
                          @calum no please no ๐Ÿ˜‚๐Ÿ˜‚ should I see the pv close again if itโ€™s restricted
                            @declan clarify should it close back up at max revs
