  3. Inlet rubber3bn/3et
Inlet rubber3bn/3et
31 Posts 7 Posters 7.6k Views 1 Watching
    @ricky0115 It should be a paper type, quite common for these to let air in here when botched.
    ricky0115R Offline
    ricky0115R Offline
    ricky0115
    @calum god damn, the bike should run without the choke when I get that replaced then. Fingers crossed! Cheers
    • ricky0115R ricky0115
      @ricky0115 Use Athena, or OEM gaskets only.
      You can get some paper gasket adhesive to just ensure it's properly sealed. It's what I've used on my engines.
      ricky0115R 1 Reply Last reply
        ricky0115R Offline
        ricky0115R Offline
        ricky0115
        @calum where’s the best place to get Athena gaskets? I remember pricing up OEM on Fowler’s for the top end was like £40 for 2 gaskets
        • O Offline
          O Offline
          Just received set for the 89 bike, ordered via ebay, £20 something, used before on the 88, athena the way to go
          • O oldman
            ricky0115R Offline
            ricky0115R Offline
            ricky0115
            @oldman cheers mate!
              @ricky0115 For gaskets and obtaining authentic genuine athena gaskets. Choose none other than PJME.
              But personal preference. I use eBay for almost everything else.
                ricky0115R Offline
                ricky0115R Offline
                ricky0115
                @calum thanks, also which adhesive would you recommend?
                  @ricky0115 https://www.pjme.co.uk/acatalog/Yamaha_DT125R_Tools___Workshop_Equipment_.html
                  Loctite Adhesive Spray.
                  Bought that like 5 years ago and still use it today.
                  People will no doubt say it's unnecessary. All I can say is I've only built engines with it and never had any problems. But I'll admit it's potentially over cautious.
                    ricky0115R Offline
                    ricky0115R Offline
                    ricky0115
                    @calum it was made for a reason why not use it! Especially on that annoying gasket on top of the carb
                      @ricky0115 don’t use rtv silicone it ends up in your reed cage
