Bike running fast revs
On mine there's a little plastic clip that holds the cable into the slide, it's bright green I think - hard to miss lol.
Or is the cable outer coming loose from the carb top?@finnerz89 that green piece is missing then I don’t remember there ever being one
@declan you will never make one unless you have a 3D printer, the piece never moves use a small calbe tie it should do the job
@ricky0115 how would I position the tie bud?
@declan https://www.fowlersparts.co.uk/parts/view/3ME-1490J-00
That’s really what you need to do it properly they don’t sell it separately.
I was joking about the cable tie!
@ricky0115 your jokes are terrible lol
@ricky0115 just took the part out it already has a notch built in that stops the cable from sliding out so I’m a little confused as to how it’s actually coming loose I’m gonna try a stiffer spring
Put 2 springs on
Put 2 springs on
@scrimsmustang it seems to be sorted now put a stiffer spring in
