  3. Bike running fast revs
52 Posts 7 Posters 12.9k Views
    On mine there's a little plastic clip that holds the cable into the slide, it's bright green I think - hard to miss lol.
    Or is the cable outer coming loose from the carb top?
    @finnerz89 that green piece is missing then I don’t remember there ever being one
      @declan any chance anyone has a pic of one so I can try make one
      ricky0115R 1 Reply Last reply
      • ricky0115R
        ricky0115R
        ricky0115
        Mine was doing this, turned out to be a split gasket on the reed block spacer.
          ricky0115R
          ricky0115R
          ricky0115
          @declan you will never make one unless you have a 3D printer, the piece never moves use a small calbe tie it should do the job
          • ricky0115R ricky0115
            @ricky0115 how would I position the tie bud?
              ricky0115R
              ricky0115R
              ricky0115
              @declan https://www.fowlersparts.co.uk/parts/view/3ME-1490J-00
              That’s really what you need to do it properly they don’t sell it separately.
              I was joking about the cable tie!
                @ricky0115 your jokes are terrible lol
                  ricky0115R
                  ricky0115R
                  ricky0115
                  @declan your not the only person to say that 😂
                    @ricky0115 just took the part out it already has a notch built in that stops the cable from sliding out so I’m a little confused as to how it’s actually coming loose I’m gonna try a stiffer spring
                      scrimsmustang
                      @declan
                      Put 2 springs on
                      • S scrimsmustang
                        @declan
                        Put 2 springs on
                        @scrimsmustang it seems to be sorted now put a stiffer spring in
