  4. Dt don’t work with its own fuel tank
11 Posts 3 Posters 2.2k Views
    Check the fuelvalve and the filters in it. Also make sure fuelline has no kinks, and no blocked fuelfilter.
    declanD 2 Replies Last reply
    • J Jens Eskildsen
      • J Jens Eskildsen
        @jens-eskildsen so if the flow is blocked I get a high idle?
          @declan It'll do that if the bike runs really lean, but should cut out pretty quickly.
          I'd check the petcock as well. Ensure nothing is blocked.
            @calum I’ll pull it off tomorrow and will update you
              Blocked fuel = lean = high idle, so yeah.
              • J Jens Eskildsen
                @jens-eskildsen so I took it out and there was dog hair in the tank but tbh it didn’t look too bad I might add I was accidentally running it on reserve all this time as I didn’t know which way was which so I blew through the “on” position and it was a lot more restrictive than I would have thought is this normal?, I then sprayed wd40 through there to hopefully clear any bits our then plopped it on and runs pretty good
                  There should be a steady flow, and it should be the same in "on" af "res" setting.
                  Did you disassemble the petcock entirely?
                  • J Jens Eskildsen
                    @jens-eskildsen no it was stubborn but the bikes running great I’ll link a quick video
                      @declan https://youtu.be/r9pFrkpKKmo
                      The fuel is flowing steady
