  3. Framework
  4. Quick help for suspension service
36 Posts 4 Posters 9.7k Views
    @calum wait there’s bearings in the linkage? Not in mine there isn’t?
    @declan Item 13 is the linkage, lots of bearings
    In the event you have a collar, and no bearings (as designed from the factory) you have to be even more strict. As the you won't have the flexibility of simply replacing the bearing, you instead have to replace the whole item.
    Oh so for example, Cam Shaft Journals on a Four Stroke engine. Since the cams run directly onto a Journal, no shells or bearings, if you damage the Journal you destroy the head.
    It's far cheaper to replace the cams than it is to replace the head. That's the idea.
      @calum mine is just the bushings theres no place for bearings bud i simply don’t have the funds right now but I do understand what your saying it’s just not possible for me right now
        @declan I can't see how your linkage could not have bearings lol. It would be horrendously slack and would never get an MOT.
        As I said, if by some strange event you don't have any bearings there, you will destroy the part and it'll cost you £105 for a new linkage rather than the £10 for the bearings.
        That's the point I'm trying to make.
        I personally don't understand the mentality of scrimping.
        I bought my car 3 years ago and it has been absolutely neglected. Whilst I do really need this car, I haven't driven it until everything has been rectified. We're talking everything, the car has simply sat still. I actually cycle everywhere lol, it's pretty tragic. So I understand having the lack of funds, but the way I see it, it will cost more in the long run if you don't sort it out.
          @calum like I said it’s just something I gotta do and the bike ain’t going anywhere anytime soon anyway, so help me understand some have bearings but mine doesent?
            @declan Throw some photos up. The linkage, item 13, has bearings inside it.
              @calum I’ll do a video 2 mins
                @declan https://youtu.be/nRHOTgstx3U
                  Yeah yeah that's sound. That's the bronze bush. But the other part of the linkage, will have bearings in it.
                  That collar sits inside the bronze bush, the two should be replaced at the same time. I would polish the collar, and pack the linkage full of grease.
                    @calum can’t get the other one out can move it a bit but that’s it I’ll have a go from the other side tomorrow as it must be as dry as the Desert
                      @declan Oh, I would probably leave the bronze inserts in there bud.
                      So long as the collars have not up and down play then that's fine. Just grease it all up.
                      Those bronze collars will wear rather than the linkage.
                      Once they have worn past their limit, the collar and bush will have play. But the outer side of the bronze bush should be fine. WHich means the linkage should be find
                        @calum got it out cleaned and used a crazy amount of grease just waiting for the dog bones to dry still didn’t come across Any bearing a tho bud
                          @declan they slide in nicely now
                          • F
                            Definitely should be bearings in there 🤔
                              @finnerz89 Nah not in that part. It's the part that sandwiches between the frame that has the needle bearings. It's just a collar on the bronze bush for the bit declan is working with.
                                #25
                                @calum so the bearing are up at the engine side I wanted to get em out but the bolt is too hard to get to it moves smoothly enough though so I think it’s fine
                                  @declan Yeah mate. All I can say is good luck lmao.
                                  They poooorroopperly seize in their.
                                  The trick is to soak that part for at least a good 24 hours.
                                  And then on reassembly, grease the balls off it.
                                  That part always seizes as there is not grease nipple IIRC.
                                  But yeah that's a good one to replace as it's going to exhibit the most stress.
                                    @calum hopefully I can get to it in the future but atleast the collars that were borderline seized will be good for a while it’s almost like they don’t want you to get to it so then you need to buy expensive bearings and in some cases pay Yamaha to do it I think I’m on to something 😏
                                      @declan Nah, the main ones have grease nipples on. Blame poor owners who don't bother looking after them.
                                      Ultimately it's likely they've never been removed, or properly serviced, it's a miracle they've survived that long.
                                        @calum yeah it’s a real shame it’s not been looked after leaves me picking up the slack
                                          @declan Trust me, the bike will be that much better once you've put the effort in.
                                          declanD 2 Replies Last reply
