  3. Carb clean abs rebuild help
33 Posts 4 Posters 7.8k Views
  • terry.tzT
    terry.tzT
    terry.tz
    but the choke is not and you are putting more fuel in from the choke I don't know just saying its possible and when your at mid revs the choke might not give either fuel also and from my understanding, they lean out mid revs before getting rich again so could be a problem just what I would be thinking about if it was me I mean I would try what he has done, to be honest, but I would be like to fix it asap
    • terry.tzT terry.tz
      @terry-tz Hey, ditto...
        @finnerz89 It's driven off a nylon cog directly from crankshaft. So yes and no. It is driven from both the throttle and crank.
        @calum I could've worded that better, driven off the crank, controlled by the throttle. Either way a rich fuel/air mix won't really affect the amount of oil supplied by the pump will it?
          @finnerz89 I think, in this instance, the fuel change is so little that it's not really the issue here.
          The issue is that putting a washer behind the choke isn't fixing the problem, and I think we're all in agreement with this.
          F 1 Reply Last reply
            @calum most definitely lol
            • terry.tzT
              terry.tzT
              terry.tz
              @Calum agreed but the oil might still be an issue as the choke is not driven off the throttle and is supplying some fuel without the throttle ie no oil well low oil relative to fuel and it probably won't keep enough flow in the mid-range so low oil plus low fuel I would be riding with caution unless I was confident I was getting enough might not be much difference but I suppose it depends on what you use your bike for
                @terry-tz I’m not by any means saying that this is a perfect fix but it’s yhe best I can do at this time
                • terry.tzT
                  terry.tzT
                  terry.tz
                  @declan I'm not digging mate I would probably do the same I mean I been running mine with twisted bottom yoke from were I came off, br10 plug no br9's at the time, buckled front wheel and a few things holding together with cable ties 😁 and a few other bits and bobs just pointing out the risks of not fixing
                  terry.tzT 1 Reply Last reply
                    terry.tzT
                    terry.tzT
                    terry.tz
                    @terry-tz oh ye guys remember the thread about iridium plugs well I restricted my bike for a friend never ridden before and it went around the field and the plug was foiled tried cleaning multiple times like 5 - 10, in the end, i put the br10es in iridium plugs are sh!te I tried them one last time and it let me down that's the last time I ever use one again
                      @terry-tz I've ran iridium plugs in mine with no issues, can't say I noticed a difference to standard though
                        terry.tzT
                        terry.tzT
                        terry.tz
                        @finnerz89 there ok just no reliable at all like you probably have your bike running sweet were as mines, not that sweet running and I restricted it which made it more oily so I mean if your all done tinkering there ok but for the extra price for the not so noticeable performance gain you might as well burn your money and set off early for everything in case you need to change a plug very slightly exaggerated
                          @terry-tz haha πŸ˜‚ were yours genuine NGK's? I've heard there's a lot of fakes knocking about on eBay that really are shite
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @finnerz89 not the first time I heard this lol so i got it from www.sparkplugs.co.uk
                            • terry.tzT
                              terry.tzT
                              terry.tz
                              that's the reason they had another chance
                              • F
                                Ahh fair enough then. Every bike is different lol
