Headlight blowing
@oldman But even if that is the case, 16v over the lights seems too much to me for a 12v bulb.
@calum said in Headlight blowing:
Yeah thats why the bulbs are blowing, mind you they will blow even if the battery is on its way out also. Even if reg/rec is good.
Replacement reg/rec arrived today, fitted, max voltage at headlight 14v, no blowing bulbs! Anyone know test procedure for old one? Would like to confirm failure because I am ****
Ta -
On the old one the yellow cable has a mark that looks like carbonisation but no visible breaks in insulation (even with magnifying glass), could be insulation breaking down? Has not been pinched or damaged in any way and looks whole bar the markon the cable. Have seen before in commercial building applications, will check wiring diagram to identify cable and see if that could have caused failure, photo below.
Have cleaned off surface btw to show cable surface, black coating previously. -
As said, the rectifier IIRC is just a bunch of diodes. Diodes restrict current to one direction. So the rectifier will correct AC to DC. It's the regulator that should regulate the voltage.
If the bulb is designed to dissipate 50 watts on a 14V DC supply, and you suddenly start feeding it 16V AC, well there is your answer.
