  3. Top End
  4. Time to change wheels and ...
47 Posts 7 Posters 16.1k Views
  • Y
    Y
    Yegor
    That's great ! Maybe you know if the YAMAHA XT125X 2005 Wheels
    ( Front: 100/80x17 - Rear :130/70x17 )
    fits on Yamaha DT 125 R 2003
    ( Front: 80/90-21 - Rear: 110/80-18 )
    ? ( I mean hub dimensions )
    • Y Yegor
      @yegor like Calum says anything will fit if you want it to but you could also lace the dt hubs onto sm rims
      • Y
        Y
        Yegor
        @declan That's great idea .
        • Y
          Y
          Yegor
          wrote on last edited by Yegor
          Hello ! Now I will try to explain my situation with photos ( sorry for my english )))
          first, I had a problem with yamaha dt lip seals ( water pump) ( the motorcycle was stopped more than half a year) , I changed it, but after that , the next day riding my bike the rear wheel suddenly blocked. Now I disarmed the cylinder and you can see whats going on. So I cant imagine why that happens , original cylinder and piston only 10000 km. And it's almost impossible to put it wrong the water pump and seal. ( or not
          • The Yamaha DT 125R cylinder is sleeved ( iron ? ) can be repaired. or go for Athena )
          • Can it be the fault of the oil pump ? how to check itΒΏ ( the engine thermostat works well.)
          Usualy I buy in Wemoto.com . Thank you in advance !
            Embed me!
            Yeah, you can bore that out no problems.
            Ensure you modify the powervalve to the right spec. Otherwise you will risk having the powervalve come into contact with the piston.
            • Y
              Y
              Yegor
              @Calum You mean just adjust the power valve position ? ( cables ) Thx !
              CalumC Irongamer727I 3 Replies Last reply
              • Y Yegor
                @yegor No, you physically have the modify the powervalve after a rebore.
                • Y Yegor
                  @yegor Athena!
                  • Y Yegor
                    @yegor but sort out why it seized first pleaseπŸ˜‰
                    • Y
                      Y
                      Yegor
                      @Calum thx again! do you know how to extract the power valve from the cylinder ? ( for cleaning and modify )
                      @Irongamer727 Ok ! )) Do you need to readjust the oil lubrication after install the Athena kit ?
                      Thx a lot .
                        There is a bolt that goes through the powervalve, can be unscrewed from the front right of the cylinder. Behind the powervalve cover from the clutch cover side.
                        • Y Yegor
                          Thx a lot .
                          @yegor some go premix some don't. I will go with the pump when installing my kit
                            A slight rebore shouldn't affect the powervalve πŸ™‚
                            • J Jens Eskildsen
                              @jens-eskildsen Yes it will.
                              If the bore is stock (getting rarer these days and not worth assuming) then no, you're right. But once you start going over the first rebore size, modifying the valve is a must.
                              To save confusing, I said modify the valve just as a precaution.
                              • Y
                                Y
                                Yegor
                                Yes, the cylinder was rebored at least once. Now I'm looking where do that again. Thx !!
                                @Calum > ?
                                • Y Yegor
                                  @Calum > ?
                                  @yegor Yeah that's the pup.
                                  • Y
                                    Y
                                    Yegor
                                    @Calum **thanks to everyone ** . One question ( maybe a little bit stupid) XD . What material the cylinder is made of ? And the cylinder sleeve ? ( Yamaha DT 125R )
                                    The cylinder sleeve Iron?
                                    Cylinder Aluminium ?
                                    Have you tuned Yamaha cylinder ? ( admision / exhaust transfers etc ?)
                                    Cheers !
                                    • Y Yegor
                                      Cheers !
                                      @yegor YEah that's correct. I imagine the bore will be a steel alloy.
                                      I've had my barrel ported by a tuner.
                                        @calum how much did that cost bud and can it just bolt back on no jet changes etc
                                          @declan No, porting is going to drastically change the characteristics of a two stroke engine.
                                          I wouldn't advise it on a daily, or on stock ignition.
                                          You don't get something for nothing. I'm not going into it here, but the principle is, peak almost always alters performance elsewhere, usually torque.
                                          There are exceptions where engines are poorly designed and modifications improve performance with no effect. But the end of it is, these engines are pretty well designed. When it comes to porting them, you're making a sacrafice somewhere else in the rev range for more power.
