  3. Top End
  4. Time to change wheels and ...
47 Posts 7 Posters 16.1k Views
  • Y Yegor
    @Calum You mean just adjust the power valve position ? ( cables ) Thx !
    @yegor but sort out why it seized first pleaseπŸ˜‰
    • Y
      Y
      Yegor
      @Calum thx again! do you know how to extract the power valve from the cylinder ? ( for cleaning and modify )
      @Irongamer727 Ok ! )) Do you need to readjust the oil lubrication after install the Athena kit ?
      Thx a lot .
        There is a bolt that goes through the powervalve, can be unscrewed from the front right of the cylinder. Behind the powervalve cover from the clutch cover side.
        • Y Yegor
          Thx a lot .
          @yegor some go premix some don't. I will go with the pump when installing my kit
            A slight rebore shouldn't affect the powervalve πŸ™‚
            • J Jens Eskildsen
              @jens-eskildsen Yes it will.
              If the bore is stock (getting rarer these days and not worth assuming) then no, you're right. But once you start going over the first rebore size, modifying the valve is a must.
              To save confusing, I said modify the valve just as a precaution.
              • Y
                Y
                Yegor
                Yes, the cylinder was rebored at least once. Now I'm looking where do that again. Thx !!
                @Calum > ?
                • Y Yegor
                  @Calum > ?
                  @yegor Yeah that's the pup.
                  • Y
                    Y
                    Yegor
                    @Calum **thanks to everyone ** . One question ( maybe a little bit stupid) XD . What material the cylinder is made of ? And the cylinder sleeve ? ( Yamaha DT 125R )
                    The cylinder sleeve Iron?
                    Cylinder Aluminium ?
                    Have you tuned Yamaha cylinder ? ( admision / exhaust transfers etc ?)
                    Cheers !
                    • Y Yegor
                      Cheers !
                      @yegor YEah that's correct. I imagine the bore will be a steel alloy.
                      I've had my barrel ported by a tuner.
                        @calum how much did that cost bud and can it just bolt back on no jet changes etc
                          @declan No, porting is going to drastically change the characteristics of a two stroke engine.
                          I wouldn't advise it on a daily, or on stock ignition.
                          You don't get something for nothing. I'm not going into it here, but the principle is, peak almost always alters performance elsewhere, usually torque.
                          There are exceptions where engines are poorly designed and modifications improve performance with no effect. But the end of it is, these engines are pretty well designed. When it comes to porting them, you're making a sacrafice somewhere else in the rev range for more power.
                          • Y
                            Y
                            Yegor
                            Hello ) !
                            I will go tomorrow to the workshop with the cylinder for bore. I know is privileged information and long testing time but do you know where I can find information about tuning cylinder transfers, I think is good idea do something there before it will be bored. Maybe in the same workshop they do that for extra €, will ask.
                            all this marked with color dots can be modified/enlarged : ?
                            at the top of ALL the transfers: (?)
                            so, thank you again for the help, and gas gas !
                              Depending on how good your English reading is, I HIGHLY recommend Graham Bell's Two Stroke Performance Tuning.
                              That will give you a lot of knowledge on tuning two strokes.
                              I would NOT recommend porting the barrel, or altering the port timings, without a programmable CDI.
                              • Y
                                Y
                                Yegor
                                wrote on last edited by Yegor
                                #29
                                @calum said in Time to change wheels and ...:
                                Thanks for the tip Calum . also I have dowloaded the Two-Stroke TUNER'S HANDBOOK By Gordon Jennings. Time to read.
                                ( http://www.2strokeengine.net/gordonjennings/twostroketunershandbook.php )
                                so, for now I'm going to polish a little bit where it is needed , also the power valve , because it is very dirty.
                                Mitaka pistons are good ? where you can buy original Yamaha DT R parts online ( like water pump complete repair kit) ? <--- have find this official site : http://www.recambios-yamaha.com/es/dt125r/2002/bomba-de-agua.html
                                Thank you very much everyone, your answers are very useful.
                                • Y Yegor
                                  @yegor I'd recommend PJME, they're based in England but are Two Stroke Specialist, I believe they ship world wide.
                                  Polishing will get you so far, gasket matching is going to be far more effective.
                                  If you're going for performance, I'd avoid mitaka. Nothing wrong with them, but they are cheap CAST pistons designed to offer a cheap alternative to OEM.
                                  For performance, go forged. Grab yourself a forged Wiesco piston and a set of chromium rings.
                                  • Y
                                    Y
                                    Yegor
                                    can't find Wiseco ( one ring ?) piston for my model. But in PJME I have find Wossner piston ( 2 rings) , they are good I think, also forged (?)
                                    Do you know if in PJME there Wiseco piston for the DT R ?
                                    waiting answer from this site . http://www.paramimoto.com/pistones/343-wiseco-piston-yamaha-2-tiempos.html#/piston-dt_125_75_76_684m05600
                                    • Y Yegor
                                      @yegor Ahh yeah sorry mate, vertex and Wossner are perfectly good forged components, I run Wossner myself, but will be switiching to wiseco for my new engine I'm building.
                                      For reliability, I'd stick to twin rings rather than just one.
                                      • Y
                                        Y
                                        Yegor
                                        #33
                                        Hello friends !
                                        Finnaly I've recived the piston. While they still fix the cylinder, I am reading carburation manuals and cleaning the Mikuni. I'll buy carburetor jet kit from 180 to 250.
                                        I have noticed that the Yamaha piston rings are different while the Wossner ones are the same:
                                        The Small End Bearing is 17mm ( the one that was put ) but the original bearing for Yamaha piston is 19.5 mm, so is very important replace it ?
                                        And I see that the Wossner piston does not have holes that lubricate the gudgeon pin:
                                        ( it might be a good idea to do them? although I do not think so ) )
                                        I have a base gasket but the Genuine Base Gasket it is made of metal (aluminium?) , so It is highly recommended put the metal one ?
                                        uf a lot of questions but thank you in advance . :man_biking_tone1:
                                        • Y Yegor
                                          Hello friends !
                                          @yegor as far as I know stock bikes don’t have the metal base gasket I wouldn’t bother with the lubrication hole if it was needed they would of already done it
