  4. Cylinder questions
Cylinder questions
26 Posts 5 Posters 4.9k Views
  • Irongamer727I Offline
    Correct me if I am wrong, but the Dt cylinder are made from aluminium right? But they have no nikasil coating? What are the inside coated with then? Explain someone!
      The Athena kits are plated. The stock cylinders are lined with steel bores.
        @calum I know it's a VERY debated question. But in theory, you mean the Athena kit would need little or no running in?
          It's mating the rings to the cylinder walls. You're forcing dissimilar materials against each other. Not only that, components wear together. Nothing is perfect, so the walls have imperfections, as do the rings. You want to gently mate the two items. When you refresh the rings, you're mating a worn bore to new rings. This will aggravate the components, care must be taken to again mate the components.
          We're talking thousandths of an inch, but at 12,000 rpm, you want to be damn sure they're near perfect.
            So this is the cylinder and perhaps piston I'm going to substitute my Athena kit with.
            The cylinder is in fantastic condition (or so I think) and the piston as well.
            They should be reusable right? No need for a new piston either?
            Piston and cylinder substitute https://imgur.com/a/zldHrxx
              @irongamer727 I'd have the bore honed and a new set of rings.
              Those rings looks like they could benefit from being replaced. Grab a new gudgeon pin and small end bearing. Don't forget to replace the circlips.
                @calum why hone? It's not even worn
                  The pictures don't make it far, I'll have to admit.
                    Where can I find good rings, a new gudgeon pin and circlips?
                    • 2 Offline
                      2 Offline
                      2stroketerry
                      Personaly i would get it bored to the next size as don't know how many miles the piston has done. Also regarding the bore you should have the cross hatching from the cylinder being honed but not any vertical up and down scratches like that cylinder has on it. If you don't mind me asking how much is the barrel and piston? How much are you wanting to spend as i have a spare barrel thats been fully ported and a fresh rebore on it to 57.5mm with a Mitaka piston. Also a spare set of rings with it as well as a brand new genuine Yamaha little end bearing. Has a 3MB head with it thats been skimmed and matched to the ported barrel with the correct swish and compression on it and an Athena head gasket with it that has been alterd to suit the 1.5mm larger bore size. Will post some pictures if your interested.
                      Irongamer727I D 2 Replies Last reply
                      • 2 2stroketerry
                        @2stroketerry I bought an entire engine for £85, the cylinder came with it. I'm thinking about trying this guy. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F401431331293
                        • 2 Offline
                          2 Offline
                          2stroketerry
                          Hi, yes a few people on this forum have had there barrels re bored by him and said his work is good and you won't find anyone cheaper.
                          Irongamer727I declanD 2 Replies Last reply
                          • 2 2stroketerry
                            @2stroketerry so it's worth a try?
                            • 2 2stroketerry
                              @2stroketerry just out of curiosity how much is that barrel set up for sale for?
                                I wpould go to PJME for my stuff.
                                The hone is just a refresh to restore the crosshatching. I disagree about the rebore unless its out of round, but a decent honing place can decide this for you and order the piston in.
                                  @calum £96 for postage with piston, rebore and all that feels pretty good.
                                    @irongamer727 From PJME?
                                      @calum ehhm no, that eBay guy
                                        @irongamer727 Oh ryt. Well is the piston any good?
                                        I'd recommend PJME as they're the best in the business. Nothing beats the best.
                                          @calum well if it were me I'd just buy new rings, gudgeon pin and small end and use everything.
