  3. Carburetor
  4. Dt125 mikuni carb
Dt125 mikuni carb
37 Posts 4 Posters 11.2k Views
  • Glynn123G Glynn123
    Removed that little airbox bottle on mine, can't say I noticed any difference but bike runs strong with pleanty pull with it removed and plugged.
    @glynn123 There are better ways to restrict the bike than some plastic box on the inlet tract lol.
    I don't know the science behind it, I figured it would work in a similar fashion to the YEIS. But it's as mystery.
    The DTRE also had YAIS as well.
    • Irongamer727I
      My Haynes manual says stock pilot jet fit the Dtx is 17.5? What the hell? Thought it was 25.
      K 1 Reply Last reply
        K
        K
        kevin
        @irongamer727 first flatslides came with 22.5 and later models 17.5 and 210 mainjet
        • K kevin
          @kevin Alright, thx
          • Irongamer727I
            So I was finally able to unscrew my pilot jet for my dtx. It is a nightmare to start now with the Athena kit. I looked in the Haynes manual and it claimed stock pilot jet for the dtx was 17.5.
            Mine was a 35! What on earth? How is it possible it is hard to start NOW and not when it was 100% stock?
            Pilot jet size 35 https://imgur.com/gallery/fS02dV8
            • Irongamer727I
              Either way, it is too big right?
              • Irongamer727I
                Response please...
                  Ask any tuner how to set up a carburettor and you'll get the same response.
                  It depends on your setup.
                  Everything from Atmospheric conditions to state of the engine and even altitude will affect jetting.
                  It's imperative that ones carb is tuned to these varying conditions.
                  20 years ago, Yamaha spent thousands on designing the perfect carburettor settings to get the DT roughly in the right ball park.
                  The moment you started modifying the bike, you throw all of Yamaha's hard work out the window.
                  Just because it had some ridiculous settings on it, doesn't necessarily mean it was wrong.
                  Jetting should be done to suit, and there is reams of guides on here to help you get the bike in right area.
                    @calum guess so. Only way is to buy and try stuff I guess
                      Response please...
                      K
                      K
                      kevin
                      @irongamer727 I’m a firm believer in leaving things the way they are and not thinking I’m better than the designers.
                      To answer your question 35 is very big for your carb.
                      Does Athena give any tips on resetting.
                      You say it’s hard to start, have you checked the fuel feed pipe when the cold start lever is on as it’s very narrow and often gets blocked.
                      • K kevin
                        @kevin nope. Athena don't give any recommendations at all. Do you mean the fuel hose itself? That's brand new. The choke works, could there be some debris in the mechanism you think?
                          K
                          K
                          kevin
                          @irongamer727 thin brass pipe near to the hole the pilot jet drops in is the fuel pipe whilst on the choke cycle, very thin wire needs poking down to the bottom and then through the cross holes.
                          • Irongamer727I
                            Alright so as I'm getting progressively better at them wheelies and can ride longer, I've noticed stuff. The carb wants to piss out the transparent liquid gold (petrol).
                            Is tilting the carb the only way to go? Or could a float adjustment do the trick?
                              @irongamer727 Sounds like the flat is causing you issues.
                                @calum the flat?
                                  @calum the flat?
                                  @irongamer727 Float sorry.
                                    @calum would I want to raise or lower it?
                                      @irongamer727 Just make sure it's shutting off the fuel bud
                                        #31
                                        @calum won't that affect my crusing, regular riding?
                                        I mean the carb will tilt almost 90° on a real wheelie.
                                        I've spoken to some guys really good at that rear wheel (they ride a dt) and some of them just plug the overflow. But I mean it's clearly leaking for a reason. Can't understand how plugging the owerflow works.
                                        • Glynn123G
                                          Glynn123G
                                          Glynn123
                                          As far as I'm aware if you plug the overflow it will still dump the fuel, but it will dump it out the rear intake of the carb into the airbox, which will then get sucked into the engine. Never had or seen any problems with standard Dt carb during wheelies, and I know people who regularly scrape and coast.
