  3. Off Topic
  4. Opinions Honda NSR 125 1989
72 Posts 7 Posters 23.5k Views
  • D
    When I was running my nsr richer it was easy to start didn't even need choke. But since running it on leaner jetting it takes abit of tweaking but is loads livelier on the road.
    • D DTR+NSR
      @dtr-nsr does your have a lot of low end power? Mine doesn't, but at 8-12k rpm it moves!
      Sixth gear is really not useful. Going 80km/h in sixth gear and twist the throttle nothing happens. Sounds familiar?
      • D
        I wouldn't say alot, but it noticeably improved with leaner jetting. Like you say power really comes in about 8krpm. Mine easily pulls to 80mph, you have to take it to the redline in 5th before changing into 6th and be well tucked in for it to pull in 6th I've found.
        • D DTR+NSR
          @dtr-nsr happy to hear. I didn't redline in 5th at around 120 km/h and when I changed gear I lost everything 😛
            What's the powervalve setting on these?
              @calum said in Opinions Honda NSR 125 1989:
              There open at idle up to 2000rpm, then closes and starts re-opening at about 7500rpm. There's a hi and low mark on the power valve pulley you line up, but I've found like with dt your best checking up the exhaust port, to check there fully open. Some cdi and power valve controllers are restricted though.
              • D DTR+NSR
                @dtr-nsr from what I could see through the exhaust port, the pv didn't seem to be able to be perfectly aligned with the port at all.
                  They srvo operate then?
                    @calum yes of course.
                      @irongamer727 Well not of course, Early Aprilia RS 125's and the tuned ones, run pneumatic valves.
                      KTM EXC's Yamaha YZ's and Kawasakis KIPS run off the gearbox.
                      So the valve could have been actuated by any of those.
                        #69
                        @calum Thought you would know for sure. Anyway the pv on the Honda is shit compared to the DT. It's like two different worlds. There is really no low end power on the Honda
                          @irongamer727 I've never worked on Hondas.
                            @calum it's time then 😉
                              @irongamer727 The NSR simply is not as high as spec as the Aprilia is, it frails in comparison.
                              Now a Honda RS 125 I definitely would love to hand. Shame I don't have 10K lying about the place.
                              They run their powervalve off the gearbox I believe.
