  3. Carburetor
  4. Dt125 mikuni carb
Dt125 mikuni carb
37 Posts 4 Posters 11.4k Views
    @kevin nope. Athena don't give any recommendations at all. Do you mean the fuel hose itself? That's brand new. The choke works, could there be some debris in the mechanism you think?
    K
    K
    kevin
    @irongamer727 thin brass pipe near to the hole the pilot jet drops in is the fuel pipe whilst on the choke cycle, very thin wire needs poking down to the bottom and then through the cross holes.
    • Irongamer727I
      Alright so as I'm getting progressively better at them wheelies and can ride longer, I've noticed stuff. The carb wants to piss out the transparent liquid gold (petrol).
      Is tilting the carb the only way to go? Or could a float adjustment do the trick?
        @irongamer727 Sounds like the flat is causing you issues.
          @calum the flat?
            @calum the flat?
            @irongamer727 Float sorry.
              @calum would I want to raise or lower it?
                @irongamer727 Just make sure it's shutting off the fuel bud
                  #31
                  @calum won't that affect my crusing, regular riding?
                  I mean the carb will tilt almost 90° on a real wheelie.
                  I've spoken to some guys really good at that rear wheel (they ride a dt) and some of them just plug the overflow. But I mean it's clearly leaking for a reason. Can't understand how plugging the owerflow works.
                  • Glynn123G
                    Glynn123G
                    Glynn123
                    As far as I'm aware if you plug the overflow it will still dump the fuel, but it will dump it out the rear intake of the carb into the airbox, which will then get sucked into the engine. Never had or seen any problems with standard Dt carb during wheelies, and I know people who regularly scrape and coast.
                    • Glynn123G Glynn123
                      @glynn123 someone's got to be the first😛🔫
                      Glynn123G 1 Reply Last reply
                        Glynn123G
                        Glynn123G
                        Glynn123
                        @irongamer727 doesn't seem like you're having much luck with this build mate haha
                          Plug the overflow lol, that's just masking the problem.
                          It'd be overflowing for a reason and the float is a pretty well balanced item, meaning it shouldn't just purely on gravity. You'd have the be upside down for it to shut, at which point you won't be needing any fuel.
                          I'm not saying adjust it, I'm just saying make sure it does shut off the fuel.
                            @glynn123 Hehe I mean I'm learning stuff at least, the engine is healthy and all but I guess some things should just not be this hard.😛
                              @calum
                              I should just be able to tilt the carb ~80 ° and just make sure it closes then. Hopefully a quick fix.
