  3. Few problems with my dt125re
15 Posts 4 Posters 3.0k Views
  • B
    B
    BraDT
    Checked the swing arm last night no clanging or bangs only slight movement I will leave the swing arm till last want the pv sorting first
    Might aswell give the pv a clean while I adjust but how do I dismantle ?
    Many thanks
    • B BraDT
      Many thanks
      @bradt If there is any play in the swingarm, and you ride it, you risk damaging it further, failure that, the shock.
      It will also reek havoc on your wheel bearings as well.
      Any suspension component will have consequence, big or small, on many other parts.
      If this were me, I'd look to sort that out as a priority.
      Just my two pence on the matter.
      • B
        B
        BraDT
        Bike not been rode at minute iv took it off road to get something things sorted and painted
        But thanks will get that sorted soon as
        • B
          B
          BraDT
          Right so iv got round to ordering some new parts,
          New battery
          New starter relay
          New gear shaft seal
          And a few other bits
          So iv got round to changing my battery and a new starter relay, turn ignition can hear pv doing its cycle all lights etc work fine, I go to press the starter button and believe it or not it clicks but it’s only a faint click not as loud as before I changed these things,
          So where do I go know ? I haven’t got anything to read the volts with me and wanna get it sorted tonight for the weekend, has anyone got any info or anything else I can try as bumping starting it ever other day it’s killing me slowly ?
          Any info appreciated I have a video but unsure how to upload
          • B BraDT
            New battery
            New starter relay
            New gear shaft seal
            @bradt Upload it to YouTube and post a link. 😉
            • B
              B
              BraDT
              @NINJA cheers mate get it done soon as
                You need to have solid connections from the batter to the starter motor. That thing will zap loads of juice so the connections need to be fresh.
                • B
                  B
                  BraDT
                  wrote on last edited by BraDT
                  Tried connecting starter motor and nothing no sparks from battery or anything starting to get annoying.
                  Found a new starter on eBay 0_1526242547199_3B68CF72-4D07-4246-B93D-C3DD4BF19E7B.png
                  Seems really cheap from Yamaha prices anyone experienced this item ?
                  Also seen a kickstart conversion on eBay for £100 everything I need but a lever, do I risk the new starter motor or just go for the kickstart ? Opinions?
                    To be honest, not much technology in the starter motor, so wouldn't be surprised if they're cheap.
                    Aprilia ones cost about that too.
                    You can get them rebuilt. Probably cost more.
                    I'd do an impedence test first, see whether or not the motor has failed.
                    Put the kickstart conversion on the wish list, as it's definitely something worth having, but as a last resort. It's nice to have the leccy working as is first.
                    • B
                      B
                      BraDT
                      @Calum might sound stupid but what do you mean by Impedance test and how can I do this ?
                      • B BraDT
                        @bradt The system will incur a known internal resistence with itself, known as impedence. This can be measured. It should fall within a tolerable range, as described by the technical specification of the item. Compare your component against this documentation to ensure the item is within tolerance.
                        Chances are, if it is, then the item is not faulty.
