  3. Husky cr 250
Husky cr 250
34 Posts 4 Posters 6.3k Views
  • M Minia
    @declan Hey. No I did not own any of these, only know about them from friends who bought some. But pretty much all cross/enduro bike seats are fitted the same way. You should just have 2 screws either side at the rear of the seat that screw directly into the subframe or 1 center screw that goes directly through the seat at the back. I know with vibrations and shocks sometimes the threads are ripped out.
    Am I right in saying this is what you are talking about? If it's just going around in circles then you might have to just find a way to successfully force it out.
    @minia that’s the one but I found out it’s been replaced with something identical recently only it’s a bold with an nut on a flat head bolt so I was turning the bolt it’s all sorted now rode it today and it is crazy so much power
    M 1 Reply Last reply
      M Offline
      M Offline
      Minia
      @declan Welcome to the world of 250 2-stroke power on <100kg bikes. Glorious ain't it? haha
      • M Minia
        @minia yeah I’m gonna die lol just needs a new clutch and I can get used to it
          M Offline
          M Offline
          Minia
          @declan Clutch should be an easy fit. I burnt the clutch on my GasGas, hardest bit was to find the actually parts I needed. Was a pain.
          • M Minia
            @minia mine stalls if you don’t rev it in gear and bites soon as you loose the lever never done one before did you use a torque wrench? I don’t think I will
            CalumC M 2 Replies Last reply
              @declan You'll need to torque the clutch springs up. Doesn't have to be a super expensive one. I got a Laser one I use for my engines. 1/4" 25Nm sees most things inside the engine, bar the flywheel nut.
                M Offline
                M Offline
                Minia
                @declan If playing with the lever doesn't do it and the bike doesn't stall in neutral then you have clutch issues.
                I would personally drain the oil and take off your clutch cover and check to make sure your clutch springs are correctly torqued. You will need a torque wrench and a manual to find the parts and specifications, you can probably find one online. If your clutch springs are correct, then some new parts are in order. If they aren't, you can have a go at torqueing them up to the correct specification, putting oil in and seeing how it performs. Again, personally, I would take it all apart and make sure your plates are within good limitations. It is a very simple job to do as long as you're confident, it will also allow you to see how the bike has been maintained.
                • M Minia
                  @minia the bike stalls in gear after like 5 seconds unless I blip it it’s a shame really clutch will cost 60 and then the wrench it’s money I don’t have but that’s life from what I’ve read no manual was made for these bikes it don’t die in gear if it’s say on the garden and not properly warmed up
                    @declan I think I’ll get the cover off soon lads the shop didn’t even put the plug in it wasn’t even tight so maybe there’s a chance it’s on low oil or wrong oil?
                      M Offline
                      M Offline
                      Minia
                      @declan Of course there is a manual mate. Give it an oil change if you think it is required. Can't go wrong with that.
                      http://www.husqvarnafactory.nl/pdf/2004/2004_WSM_WR-CR_250.pdf
                      declanD 2 Replies Last reply
                      • M Minia
                        @minia ahhh life saver mate thank you
                        • M Minia
                          @minia you have got to be fucking kidding me https://imgur.com/a/7FB24rX
                            Is that snapped off or missing?
                            Either way there is your problem.
                            No biggie though, easy fix.
                            • Irongamer727I Offline
                              I did that on my DT. I managed to unscrew it somehow anyway. Luckily I have a spare engine so I could fix it right away.
                                @calum it’s snapped so I need a new basket
                                  @calum the threaded cylinder is snapped so I have no thread to screw one back into unless I can helicoil or something similar
                                    @declan It's not totalled mate. You can take it to someone competent, they will just drill the existing bolt out without damaging the thread. Simples.
                                      @calum it’s not there bud the entire thread that the bolt goes into is gone completely there’s no left over bolt
                                        @declan Oh ryt, yeah, you would need to tig it back on.
                                        I've seen these happen before when someone tries to under the clutch center bolt without the proper tool.
                                        Yeah, again, it's not the end of the world. A piece of bar can be machined out and tig welded into place. But you're probably better off getting a new basket.
                                          @calum wouldn’t be able to afford one by luck there’s a second hand one on eBay 20 pound but it’s not in the best of condition but I really don’t have a choice
