  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 62.5k Views
  • Louis-DT-WRL
    Louis-DT-WRL
    I believe the dt200r is a 3ET barrel. Dt200wr and wr200 share the same 3xp cylinder which is nickasil plated but you can buy steel sleeves for them. I believe the dt200wr is autolube and has a tachometer at generator different dor the electrics
    Also the dt230 cylinder and crank is a possibility 🤑 never seen this one done.
    • 2
      2stroketerry
      Best option is to get your standard 125 barrel re-sleeved to 66mm then fit a Wiseco Forged Yamaha BLASTER YFS 200 Piston Kit 66mm. Piston gudgeon pin and small end bearing same size as dt 125, you will also need your head machining to suit. Kpm or Pjme will re-sleeve the barrel to 66mm and machine the head to match and also works out including forged piston kit and work to barrel and head less than half the price of the Athena kit. Also having a steel liner gives you the option of several rebores. https://www.ebay.com/itm/Wiseco-Yamaha-BLASTER-YFS-200-Piston-Kit-Top-End-Bearing-66mm-Std-Bore-1988-06-/173027889008?fits=Make%3AYamaha
      declanD Louis-DT-WRL 2 Replies Last reply
      • 2 2stroketerry
        @2stroketerry very cool I love all the little Frankenstein things you can do to engines
        • 2
          2stroketerry
          Wossner do a forged piston kit for the dt 125 that is 61mm and the absolute maximum can bore a dt barrel to. Gives around 146cc. https://www.ebay.co.uk/itm/Wossner-Piston-Kit-KTM-LC2-1991-2006-Yamaha-DT125-Over-Bore-61mm/371410153446?hash=item5679c52fe6:g:YI8AAOSwHnFVyn8J
          • 2 2stroketerry
            @2stroketerry what gains should I expect from doing the overbore and porting
            • 2
              2stroketerry
              Hi, If you get Karl at Kpmotosolutions to re-sleeve the cylinder to 66mm to suit Forged Wiseco blaster piston and machine the head to new bore size and alter squish and compression to suit. He will also fully port the re-sleeved barrel to suit your driving style, some people want a really high reving max horsepower top end like a YZ 125 for example. He can also bore out the standard Mikuni 28 TM carb to 30mm but will need to enlarge your inlet manifold to 30mm and sort your own jetting out.
              With the price of the forged piston kit, Karl re-sleeving and porting the barrel and head plus the price for boring out the carb, it will all add up to less than the Athena 170cc kit. When bored out to suit 66mm Wiseco piston the engine will be 176cc.
              With a decent exhaust on it will be over 30 bhp at the rear wheel, have to fit set of stronger clutch springs too. With all the mods done and the carb setup spot on will do 115 mph and wheelie in every gear. http://www.kpmotosolutions.com/
              • 2 2stroketerry
                Louis-DT-WRL
                Louis-DT-WRL
                @2stroketerry said in Athena 170:
                Do the windows in the skirt effect it? The blaster 200 isn't crank induction I think
                • 2
                  2stroketerry
                  Hi @Louis-James . no the windoes in the skirt don't matter and don,t affect the running at all even though dt has case induction, if anthing add slightly to the power as some 2 stroke tuners add windows to piston skirts. Strenth wise pistons are ok too
                  with windows in the skirt and being forged makes them a lot stronger than cast pistons, also a superior alloy is used in forged pistons.
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    So what's the crack with the 3bn cylinders and the tzr 2RH?
                    Been a while since talking about 125 cylinders I need a refresher.
                    How many different genuine Yamaha cylinders fit the DT?
                    Does the one of the tzr 250 cylinders fit?
                    • Louis-DT-WRL Louis-DT-WR
                      @louis-james Don't know about TZR cylinders.
                      But
                      3MB
                      3MBP
                      4FU
                      Are bolt ons.
                      The 3BN has a slightly bigger bore, so shorter stroke, as a result, a 3MB con rod will bit too long.
