  3. Framework
  4. Original lables
Original lables
7 Posts 4 Posters 1.5k Views 1 Watching
  • Louis-DT-WRL Offline
    Hello, does anyone know where to buy original/copies of Caution/warning/information stickers/lables, mostly the rear fender ones
    • Louis-DT-WRL Louis-DT-WR
      @louis-james Tell me about it...
      I know it's sad, but genuinely would like those stickers.
        @calum I know, some are reproduced.
        I believe rear fender should have.
        Monocross shock info
        Load limit
        Read manual before use
        And tyre pressures
          Load limit
          And tyre pressures
          stinkwheelerS Offline
          stinkwheeler
          @louis-james fowlers stock them for the dtx the rear fender one and its identical to the dtr one £1.50
          • stinkwheelerS stinkwheeler
            @stinkwheeler thanks, do you know which one?
              stinkwheeler
              @louis-james im not sure it just says rear fender caution label there on back order so I've ordered one with my bits I'll post a pic when it arrives
              • S Offline
                scrimsmustang
                I have 2 rear fenders with them all still on if you boys know a firm who can copy them ? Image works or someone.
