Yamaha dt125re rebuild
Wasn’t that long ago I head the skimmed and new gasket carnt see any visible leakage from bottom of the head top of barrel, I can see the odd drip coming from the hose where it connect to the head from the radiator.
But will be replacing the head gasket anyways done it plenty of times so it’s an easy enough job
But thanks for reply mate
@bradt You won't be able to see any visible leakage as it will be leaking internally - the coolant will be draining into the combustion chamber
Hi does anyone know what size the studs should be for the exhaust ?
Sitting on the bike , the right hand stud / bolt the threads are stripped does anyone know what size it should be because at the minute I’m only getting a m14 to fit but the other side is a m12
Does anyone know how deep how wide it should be thanks ?
So today I got the head gasket sorted head not warped lucky enough got it all back together and back home for a wash and wax when the weather cooled down.
https://i.imgur.com/XbDFqJ0.jpg
https://i.imgur.com/Tuag8qw.jpgNow wanting to change the white out to back so as the months go by I’ll be changing a lot more going for a stealthy look withs Yamaha blue.
Will keep more pictures uploaded
