  3. Top End
  4. It's all Calums fault
16 Posts 6 Posters 2.6k Views
    Who is Mick Andrews? Lol. Mick Abbey is who I used.
    It's worth doing if you're looking for more power, but you really need a programmable ignition system to advance the ignition to make use of the more aggressive porting.
    If the transfers are being opened then you will want a bigger carburettor to help flow more fuel/air into the engine. VHSA is a good carb. I've heard good things about Lectron carbs as well.
    It's a slippery slope for sure.
    • BluestoesonnoseB
      BluestoesonnoseB
      Bluestoesonnose
      Got the programmable Zeel unit, looking at a DT200 carb and airbox rubber.
      That's the Mick, the other one is a mate, lol
      2002 DT125R
        @Bluestoesonnose Welcome to the world of modifying. It's simple really, own a standard car or bike and enjoy it's stock performance.
        OR
        Modify it and eventually after much expense, get even greater pleasure out of your bespoke pride and joy!!! :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
        declanD BluestoesonnoseB 2 Replies Last reply
          OR
          #blamecal
            OR
            BluestoesonnoseB
            BluestoesonnoseB
            Bluestoesonnose
            @NINJA said in It's all Calums fault:
            OR
            Been doing it just like that for the last 24 years, got a a Austin A+ silly power until the gearbox kept snapping lay shafts
            2002 DT125R
              OR
              @Bluestoesonnose Oh you'll be laughing then!
                BluestoesonnoseB
                BluestoesonnoseB
                Bluestoesonnose
                @Calum said in It's all Calums fault:
                We'll see, I've still got the mental scars from tuning an RD350 and RD350YPVS in the late 80s early 90s
                2002 DT125R
                  @Bluestoesonnose Yeah, they're pretty savage beasts compared to the DTR mind you.
                  • BluestoesonnoseB
                    BluestoesonnoseB
                    Bluestoesonnose
                    Lol, yeah, but the DT is only to commute on
                    2002 DT125R
                    • BluestoesonnoseB
                      BluestoesonnoseB
                      Bluestoesonnose
                      To be honest I just want it to pull harder through the gears, not too worried about top end as I can always go up a tooth on the front sprocket if I can get it pulling from lower down
                      2002 DT125R
                        @Bluestoesonnose Getting that map sorted on the Zeel will make a big difference, and I'm not just talking about ignition timing. Don't overlook the powervalve timings, especially if you decide to have the cylinder and head ported.
                        Having the head modified will make a big difference to that mid-range power.
                          BluestoesonnoseB
                          BluestoesonnoseB
                          Bluestoesonnose
                          Cheers
                          2002 DT125R
                          • 2
                            2stroketerry
                            @Bluestoesonnose I have a fully ported Mick Abbey 3MB00 barrel with Mick Abbey skimmed 3MB head if your interested will send you some photos. Don't need it as I now have a fully ported Athena 170 kit on my DT now.
                            Glynn123G BluestoesonnoseB 2 Replies Last reply
                            • 2 2stroketerry
                              Glynn123G
                              Glynn123G
                              Glynn123
                              @2stroketerry how much you looking for 🤔
                              • 2 2stroketerry
                                BluestoesonnoseB
                                BluestoesonnoseB
                                Bluestoesonnose
                                @2stroketerry thanks for the kind offer but my head and barrel are on their way after a call to Mick. Seems for the kind of time I'm looking for a bigger carb isn't required
                                2002 DT125R
