DT200WR restoration project pic heavy
@NINJA yes, this engine had a fair few leaks I sorted today
Oil pump
Gear lever seal
Water pump.
Also putting the water pump pipe back in caused many problems, took so many attempts to get it to seal.
But now have a fully functioning to 2stroke pump 😁.. as it was from the factory.
@Louis-James Nice one, I feel your pain, as I've very recently been there myself. :pouting_face: :pouting_face: :pouting_face:
It sounds like either a lot of gaskets have perished or not been fitted properly in the first place? Either way an overhaul of em all may be prudent??? ;)
@NINJA always when someone else does work 😂
I've thoroughly checked all over. The top end had been rebuilt with a wiseco piston.
I did check that.But one of the last bits done to the engine was a new clutch and water pump seal.
@Louis-James Well hopefully the only bumps you'll see from now on, will be the ones you are jumping over MX styleee!!! ;)
So the oil pump was not flowing. Took it off and the outlet was block. Removed the hose tail and I drilled the smaller bore. Oil now flows through.
Without taking the pump alart again I am unsure if I have drilled too deep and the oil is bypass internally. By blowing through it and operating the throttle.. it doesn't seem to flow more or less on throttle position. Does there need to be drive to the pump and is it a variable gear inside is what changes the flow?
So going to have to inspect.
Or compare to another.Also bike cuts out when put into gear with stand up or down.. I think it's a faulty sidestand switch
A few little things to sort 🤣Anyway.. a few pics
Bike looks superb. Done an excellent job there. Definitely will be on that infamous hall of fame...
Yeah side stand switch is common on all bikes. Should be relatively simple to figure out.
Hopefully it's the switch and not the CDI.
Yeah pumps can be weird to diagnose, better run premix whilst you're figuring it all out!
@Louis-James The bike looks mint bud - TOP JOB!!! :thumbs_up_light_skin_tone:
Have you ridden her yet???
@Louis-James COOL she should go better with the upgrades, let us know how she handles. ;)
@Louis-James She's an enduro, so she should go anywhere you wanna take her!!! ;)
Here's a running video.
https://youtu.be/s9rmjz71dsUThat oil pump was definitely blocked inside the casting..
Got another on order. -
@Louis-James She sounds just like a proper 2 stroke should!!! :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
@Louis-James Is that the original one which came with the bike? If so why not just get it re-powder coated???
@Louis-James AAAHHHH OK - shame but I'm sure that you'll find one from somewhere??? ;)
Here's the spare set of wheels and tyres that came with the bike.
Top brand tyres to be fair.
The rear wheel is a straight swap (3bn hub with 2.15 alloy rim)
However the front wheel has a different hub... Like the late 90s yz.
If the brake discs faces offset is correct then I could turn the hub in a lathe to get the brake disc to fit,Not really sure what I want to do with these wheels. Part of me wants to build them up with purple hubs and stainless spokes.
I'd probably sell the tyres as they are MX ones
