Aprilia RS125 2010 Spain's no.1
@Calum hey, this works on my bike, right? kickstarter
http://www.wendelmotorraeder.de/kick-start-lever_ap0248365-p-3021127.html?ref=expl
@pedrobatista10 Right but you need the rest of the components. Which can be quite costly.
It is actually cheaper to just grab the whole engine, take the parts you need. Sell the rest.
can you tell me which more parts i will need? i cant find engine with kick anywere
@pedrobatista10 You need it all. Have a look at the parts diagram.
@Calum now i get your point, to buy a new engine :face_with_tears_of_joy: :face_with_tears_of_joy:
@pedrobatista10 Although the RS and MX/SX 125's share the same Rotax 122 engine, the RS has an electric start whereas the MX/SX has a kick start. You can convert the RS to a kickstart, but you will need a lot of parts like flywheel, kickstart assembly, clutch case, starter motor blank off etc. However the biggest problem is you will either have to modify or most likely totally remove the whole left side fairings, in order to kick start the engine. You would be better off just sticking with the electric start and look at other ways to save a bit of weight, if that is your goal? Look at Titanium bolts, Lithium ion battery, carbon products or just go the old fashioned way by just removing unwanted stuff.
@Calum i will need a new battery, because mine is not good.
i will take a look at lithium ion battery to buy. thanks!
@pedrobatista10 I have bought this one for my MX 125, I did find a conversion chart for Acid to Li-ion batteries, I'll try to find it for you.
https://www.ebay.co.uk/itm/LITHIUM-Best-Price-Aprilia-MX-125-Li-ion-Battery-save-2kg/281818662228
@pedrobatista10 I believe that this is the Li-on battery you need for your RS;
@Calum i found that brand for my rs, on the shop i buy all parts. 95β¬ for the battery. but its good quality, so i will go for it.
@pedrobatista10 COOL - 2.2kg lighter, and 222% more powerful, there a top quality upgrade for-sure!!!
:grinning_face_with_smiling_eyes: :winking_face: -
Sure, but if weight saving is the key then I'd go with no starter or kick starter. The idle gear isn't even on a bearing, it mates to the cases and incurs drag. You'd actually be better off binning the starter and bump starting it everywhere. Besides, the starter system is pretty light, if you go for a Lithium battery you will save yourself lots of weight
@Calum I was actually going to suggest the bump start method - pure TT race stylee. But for a road bike something a bit more refined is better. I like electric starters, much more cooler than a kick starter for-sure, which may explain why the latest MX and Enduro bikes now have them. But then as most SuMo's are converted from MX/Enduro bikes, electric starters are more common these days. The Li-ion batteries are uber cool, you only have to pick one up and compare it to an acid battery and you are sold, there featherweight in comparison. Plus they come with a built in LED charge tester, so you can easily see it's condition and it's recharges to 90% in six minutes with a compatible charger. The future is finally here for motorbikes!!! :grinning_face_with_smiling_eyes: :winking_face: :grinning_face_with_smiling_eyes:
turn signal lights from aliexpress ~11β¬ for 4 pcs
i think for this price, cant ask for more
@pedrobatista10 :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye:
@Calum i like the originals for 2010 model. But i think they are too big, thats why i bought these ones, smaller and βcarbonβ and will look good with tyga carbon parts i will add. For example, on my dtx i dont even use turn signals.
