  3. Other
  4. Aprilia RS125 2010 Spain's no.1
226 Posts 7 Posters 116.3k Views 1 Watching
  • pedrobatista10P
    pedrobatista10P
    pedrobatista10
    @Calum i will need a new battery, because mine is not good.
    i will take a look at lithium ion battery to buy. thanks!
    NINJAN 2 Replies Last reply
      @pedrobatista10 I have bought this one for my MX 125, I did find a conversion chart for Acid to Li-ion batteries, I'll try to find it for you.
      https://www.ebay.co.uk/itm/LITHIUM-Best-Price-Aprilia-MX-125-Li-ion-Battery-save-2kg/281818662228
        @pedrobatista10 I believe that this is the Li-on battery you need for your RS;
        https://www.ebay.co.uk/itm/Upgrade-Yuasa-Yumicron-YB9-B-to-LITHIUM-222-more-Cranking-2-2-kg-less/282056197778?hash=item41abdc0692:g:c98AAOSwuhhXUaAe:rk:1:pf:1&frcectupt=true
        • pedrobatista10P
          pedrobatista10P
          pedrobatista10
          @Calum i found that brand for my rs, on the shop i buy all parts. 95€ for the battery. but its good quality, so i will go for it.
            #91
            @pedrobatista10 COOL - 2.2kg lighter, and 222% more powerful, there a top quality upgrade for-sure!!! πŸ˜‰ :grinning_face_with_smiling_eyes: :winking_face:
              @pedrobatista10 Although the RS and MX/SX 125's share the same Rotax 122 engine, the RS has an electric start whereas the MX/SX has a kick start. You can convert the RS to a kickstart, but you will need a lot of parts like flywheel, kickstart assembly, clutch case, starter motor blank off etc. However the biggest problem is you will either have to modify or most likely totally remove the whole left side fairings, in order to kick start the engine. You would be better off just sticking with the electric start and look at other ways to save a bit of weight, if that is your goal? Look at Titanium bolts, Lithium ion battery, carbon products or just go the old fashioned way by just removing unwanted stuff. πŸ˜‰
              @NINJA Don't need to swap the flywheel for an RS conversion.
                @Calum I know but the RS flywheel is heavier, so if weight saving is your goal then it's worth doing.
                  Sure, but if weight saving is the key then I'd go with no starter or kick starter. The idle gear isn't even on a bearing, it mates to the cases and incurs drag. You'd actually be better off binning the starter and bump starting it everywhere. Besides, the starter system is pretty light, if you go for a Lithium battery you will save yourself lots of weight
                    #95
                    @Calum I was actually going to suggest the bump start method - pure TT race stylee. But for a road bike something a bit more refined is better. I like electric starters, much more cooler than a kick starter for-sure, which may explain why the latest MX and Enduro bikes now have them. But then as most SuMo's are converted from MX/Enduro bikes, electric starters are more common these days. The Li-ion batteries are uber cool, you only have to pick one up and compare it to an acid battery and you are sold, there featherweight in comparison. Plus they come with a built in LED charge tester, so you can easily see it's condition and it's recharges to 90% in six minutes with a compatible charger. The future is finally here for motorbikes!!! :grinning_face_with_smiling_eyes: :winking_face: :grinning_face_with_smiling_eyes:
                    • pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      turn signal lights from aliexpress ~11€ for 4 pcs
                      i think for this price, cant ask for more πŸ˜„
                        #97
                        @pedrobatista10 :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye:
                          I must admit, I do like the original turn signals. But matter of preference.
                          Even the ones I put on my DT, I can't help feel stock is slightly better styling wise.
                          • pedrobatista10P
                            pedrobatista10P
                            pedrobatista10
                            @Calum i like the originals for 2010 model. But i think they are too big, thats why i bought these ones, smaller and β€œcarbon” and will look good with tyga carbon parts i will add. For example, on my dtx i dont even use turn signals.
                              @pedrobatista10 I bought some "Red" ones for my DT, but you can tell the difference in quality between these cheap chinese ones I bought, and the carbon fibre that's on it. And I can't help feel the same for these. You'll have high quality carbon fibre parts and these may offset it.
                              But won't hurt to see what they're like. And it's your bike, keep us posted.
                              • NINJAN
                                I had similar one's on my DTR, they were not a perfect match with the other parts which I carbon wrapped, but they looked fine and you didn't really notice the difference. It's only really noticeable when there side_by_side or against each other.
                                • pedrobatista10P
                                  pedrobatista10P
                                  pedrobatista10
                                  Yes, i know this is cheap material, but i dont want to spend cash on turn lights on a reputable brand. This enough for me. If they stop working i dont care. Only 11€ wasted.
                                  Thank you so much for your feedback and help. Your bike is my inspiration ✌️✌️
                                  NINJAN CalumC 2 Replies Last reply
                                    @pedrobatista10 If you have issues with the indicators not working properly as there LED's, this thread has a ton of info on how to resolve problems;
                                    https://dt125r.co.uk/topic/613/led-indicators
                                    pedrobatista10P 1 Reply Last reply
                                      @pedrobatista10 Yeah, just to be clear, I ain't knocking by no means. I'm just speaking from experience, I am a little disappointed I binned the OEM turn signals on my DT.
                                      But I think turn signals are really important. And I happen to be slightly biased on the Spains No 1 as I sold my Spains No1 to get my DT!
                                      And I ADORED my Spains No 1
                                      • pedrobatista10P
                                        pedrobatista10P
                                        pedrobatista10
                                        spain's no 1 for me its the prettiest of all rs 125. i prefer with no.48 instead of mini with no.1.
                                        but both are amazing
                                        if i get a rs 250 my project will be spains no.1 stickers too πŸ˜„
                                          pedrobatista10P
                                          pedrobatista10P
                                          pedrobatista10
                                          @NINJA thank you sir! appreciate your help πŸ™‚
