  3. Other
  4. Aprilia RS125 2010 Spain's no.1
226 Posts 7 Posters 113.6k Views 1 Watching
  • pedrobatista10P
    pedrobatista10P
    pedrobatista10
    @NINJA thats what i will need to do! Not fitting because 2mm difference
      @pedrobatista10 So the rods are the same length, it's just the different size bolts which are the problem???
      • pedrobatista10P
        pedrobatista10P
        pedrobatista10
        • pedrobatista10P
          pedrobatista10P
          pedrobatista10
          @Calum hey, this works on my bike, right? kickstarter
          http://www.wendelmotorraeder.de/kick-start-lever_ap0248365-p-3021127.html?ref=expl
            @pedrobatista10 Right but you need the rest of the components. Which can be quite costly.
            It is actually cheaper to just grab the whole engine, take the parts you need. Sell the rest.
            • pedrobatista10P
              pedrobatista10P
              pedrobatista10
              can you tell me which more parts i will need? i cant find engine with kick anywere
                @pedrobatista10 You need it all. Have a look at the parts diagram.
                • pedrobatista10P
                  pedrobatista10P
                  pedrobatista10
                  @Calum now i get your point, to buy a new engine :face_with_tears_of_joy: :face_with_tears_of_joy:
                    @pedrobatista10 Although the RS and MX/SX 125's share the same Rotax 122 engine, the RS has an electric start whereas the MX/SX has a kick start. You can convert the RS to a kickstart, but you will need a lot of parts like flywheel, kickstart assembly, clutch case, starter motor blank off etc. However the biggest problem is you will either have to modify or most likely totally remove the whole left side fairings, in order to kick start the engine. You would be better off just sticking with the electric start and look at other ways to save a bit of weight, if that is your goal? Look at Titanium bolts, Lithium ion battery, carbon products or just go the old fashioned way by just removing unwanted stuff. 😉
                    • pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      @Calum i will need a new battery, because mine is not good.
                      i will take a look at lithium ion battery to buy. thanks!
                      NINJAN 2 Replies Last reply
                        @pedrobatista10 I have bought this one for my MX 125, I did find a conversion chart for Acid to Li-ion batteries, I'll try to find it for you.
                        https://www.ebay.co.uk/itm/LITHIUM-Best-Price-Aprilia-MX-125-Li-ion-Battery-save-2kg/281818662228
                          @pedrobatista10 I believe that this is the Li-on battery you need for your RS;
                          https://www.ebay.co.uk/itm/Upgrade-Yuasa-Yumicron-YB9-B-to-LITHIUM-222-more-Cranking-2-2-kg-less/282056197778?hash=item41abdc0692:g:c98AAOSwuhhXUaAe:rk:1:pf:1&frcectupt=true
                          • pedrobatista10P
                            pedrobatista10P
                            pedrobatista10
                            @Calum i found that brand for my rs, on the shop i buy all parts. 95€ for the battery. but its good quality, so i will go for it.
                              #91
                              @pedrobatista10 COOL - 2.2kg lighter, and 222% more powerful, there a top quality upgrade for-sure!!! 😉 :grinning_face_with_smiling_eyes: :winking_face:
                                @NINJA Don't need to swap the flywheel for an RS conversion.
                                  @Calum I know but the RS flywheel is heavier, so if weight saving is your goal then it's worth doing.
                                    Sure, but if weight saving is the key then I'd go with no starter or kick starter. The idle gear isn't even on a bearing, it mates to the cases and incurs drag. You'd actually be better off binning the starter and bump starting it everywhere. Besides, the starter system is pretty light, if you go for a Lithium battery you will save yourself lots of weight
                                      #95
                                      @Calum I was actually going to suggest the bump start method - pure TT race stylee. But for a road bike something a bit more refined is better. I like electric starters, much more cooler than a kick starter for-sure, which may explain why the latest MX and Enduro bikes now have them. But then as most SuMo's are converted from MX/Enduro bikes, electric starters are more common these days. The Li-ion batteries are uber cool, you only have to pick one up and compare it to an acid battery and you are sold, there featherweight in comparison. Plus they come with a built in LED charge tester, so you can easily see it's condition and it's recharges to 90% in six minutes with a compatible charger. The future is finally here for motorbikes!!! :grinning_face_with_smiling_eyes: :winking_face: :grinning_face_with_smiling_eyes:
                                      • pedrobatista10P
                                        pedrobatista10P
                                        pedrobatista10
                                        turn signal lights from aliexpress ~11€ for 4 pcs
                                        i think for this price, cant ask for more 😄
                                          #97
                                          @pedrobatista10 :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face::face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye: :winking_face: :face_with_stuck-out_tongue_winking_eye:
