  3. Other
  4. Aprilia RS125 2010 Spain's no.1
226 Posts 7 Posters 116.3k Views 1 Watching
    Yeah, we would buy from different Stockists, I got mine from JapPartsUK.
    A picture says a thousand words, well worth just throwing up a photo.
      Looks like mine from the photo above.
        @NINJA this part AP8121163 from tyga rear kit, doesnt fit on LEFT BALL JOINT M6 from motor.
        can you guys understand what im saying? i hope i explained well.
        anyways on tyga website they have for sale separately 2 different replacement link rod sizes.
        1- TYGA STEP KIT REPLACEMENT LINK ROD, 238MM ------- Uses M8x1.25 thread in one end and M8x1.25 L/H thread in the other. 238mm in length.
        2- TYGA STEP KIT REPLACEMENT LINK ROD, 110MM ------- Uses M6x1 thread in one end and M6x1 L/H thread in the other.
        maybe my tyga rear kit come with m8, thats why dont fit on the original m6 from my bike.
        @pedrobatista10 said in Aprilia RS125 2010 Spain's no.1:
        AP8121163
        You're talking about part No#7 in this pic I take it???
        https://www.fowlersparts.co.uk/parts/5693151/rs-125-122cc-rs-125-122cc-rs-125-122cc-chassis-number-prefix-zd4mp0-zd4mpa-1996-1998-rs-125-122cc-chassis-number-prefix-zd4mp0-z/engine
        Do Tyga make kits for different versions of the RS? Perhaps the parts you have on your bike are not the originals???
          AP8121163
          @NINJA TYGA supply new push rods for the rear sets, as there is a slight difference in construction.
          Mine was a direct fitment and they look the same as your photo. So not sure what's going on here.
          • pedrobatista10P
            pedrobatista10P
            pedrobatista10
            @NINJA the 7 from tyga set doesnt fit on the original item 10 from my aprilia. aprilia use m6 and tyga made with m8. thats the problem. but i will find out another way
              @pedrobatista10 OK so are the linkage rods the same length? If the original one's used a 6mm bolt and the new Tyga one's use an 8mm bolt, would that not mean that you will have to drill the fixing hole out to be 2mm larger? Or is there not enough metal there to do that???
              • pedrobatista10P
                pedrobatista10P
                pedrobatista10
                @NINJA thats what i will need to do! Not fitting because 2mm difference
                  @pedrobatista10 So the rods are the same length, it's just the different size bolts which are the problem???
                  • pedrobatista10P
                    pedrobatista10P
                    pedrobatista10
                    • pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      @Calum hey, this works on my bike, right? kickstarter
                      http://www.wendelmotorraeder.de/kick-start-lever_ap0248365-p-3021127.html?ref=expl
                        @pedrobatista10 Right but you need the rest of the components. Which can be quite costly.
                        It is actually cheaper to just grab the whole engine, take the parts you need. Sell the rest.
                        • pedrobatista10P
                          pedrobatista10P
                          pedrobatista10
                          can you tell me which more parts i will need? i cant find engine with kick anywere
                            @pedrobatista10 You need it all. Have a look at the parts diagram.
                            • pedrobatista10P
                              pedrobatista10P
                              pedrobatista10
                              @Calum now i get your point, to buy a new engine :face_with_tears_of_joy: :face_with_tears_of_joy:
                                @pedrobatista10 Although the RS and MX/SX 125's share the same Rotax 122 engine, the RS has an electric start whereas the MX/SX has a kick start. You can convert the RS to a kickstart, but you will need a lot of parts like flywheel, kickstart assembly, clutch case, starter motor blank off etc. However the biggest problem is you will either have to modify or most likely totally remove the whole left side fairings, in order to kick start the engine. You would be better off just sticking with the electric start and look at other ways to save a bit of weight, if that is your goal? Look at Titanium bolts, Lithium ion battery, carbon products or just go the old fashioned way by just removing unwanted stuff. 😉
                                • pedrobatista10P
                                  pedrobatista10P
                                  pedrobatista10
                                  @Calum i will need a new battery, because mine is not good.
                                  i will take a look at lithium ion battery to buy. thanks!
                                  NINJAN 2 Replies Last reply
                                    @pedrobatista10 I have bought this one for my MX 125, I did find a conversion chart for Acid to Li-ion batteries, I'll try to find it for you.
                                    https://www.ebay.co.uk/itm/LITHIUM-Best-Price-Aprilia-MX-125-Li-ion-Battery-save-2kg/281818662228
                                      @pedrobatista10 I believe that this is the Li-on battery you need for your RS;
                                      https://www.ebay.co.uk/itm/Upgrade-Yuasa-Yumicron-YB9-B-to-LITHIUM-222-more-Cranking-2-2-kg-less/282056197778?hash=item41abdc0692:g:c98AAOSwuhhXUaAe:rk:1:pf:1&frcectupt=true
                                      • pedrobatista10P
                                        pedrobatista10P
                                        pedrobatista10
                                        @Calum i found that brand for my rs, on the shop i buy all parts. 95€ for the battery. but its good quality, so i will go for it.
                                          #91
                                          @pedrobatista10 COOL - 2.2kg lighter, and 222% more powerful, there a top quality upgrade for-sure!!! 😉 :grinning_face_with_smiling_eyes: :winking_face:
