  3. Other
  4. Aprilia RS125 2010 Spain's no.1
226 Posts 7 Posters 110.2k Views 1 Watching
    Hi
    Yesterday i tried ro fit the tyga racing kit step on my rs.
    But i had some problems fitting that.
    @Calum when you installed yours it was plug n play? Or you did some modifications?
    N Offline
    N Offline
    #65
    @pedrobatista10 Post some pics of the fitting issues you're having dude, as they may offer a better insight. 😉
      Botled on no problems.
      Maybe you've been ent the wrong ones.
      • pedrobatista10P Offline
        pedrobatista10
        @Calum @NINJA
        this part on yellow, dont fit. too big one of the sides.
          How long?
          It is adjustable, the two rods can be tied in, and the anchorage on the gear shaft lever can be manoeuvred
            pedrobatista10
            @Calum im not explaining very well, sorry. its not long. problem is big size, just dont fit that tyga part. tyga part is bigger then the side it fit on the engine.
            i dont know if i explained right.
            maybe @DanRacing can help me explaining.
            N 1 Reply Last reply
              N Offline
              N Offline
              @pedrobatista10 I would contact the supplier ASAP and get their advice dude. Normally you have 14 days to return stuff, so the sooner the better really. 😉
                pedrobatista10
                @NINJA this part AP8121163 from tyga rear kit, doesnt fit on LEFT BALL JOINT M6 from motor.
                can you guys understand what im saying? i hope i explained well.
                anyways on tyga website they have for sale separately 2 different replacement link rod sizes.
                1- TYGA STEP KIT REPLACEMENT LINK ROD, 238MM ------- Uses M8x1.25 thread in one end and M8x1.25 L/H thread in the other. 238mm in length.
                2- TYGA STEP KIT REPLACEMENT LINK ROD, 110MM ------- Uses M6x1 thread in one end and M6x1 L/H thread in the other.
                maybe my tyga rear kit come with m8, thats why dont fit on the original m6 from my bike.
                  Yeah, we would buy from different Stockists, I got mine from JapPartsUK.
                  A picture says a thousand words, well worth just throwing up a photo.
                    Looks like mine from the photo above.
                      N Offline
                      N Offline
                      @pedrobatista10 said in Aprilia RS125 2010 Spain's no.1:
                      AP8121163
                      You're talking about part No#7 in this pic I take it???
                      https://www.fowlersparts.co.uk/parts/5693151/rs-125-122cc-rs-125-122cc-rs-125-122cc-chassis-number-prefix-zd4mp0-zd4mpa-1996-1998-rs-125-122cc-chassis-number-prefix-zd4mp0-z/engine
                      Do Tyga make kits for different versions of the RS? Perhaps the parts you have on your bike are not the originals???
                      • N NINJA
                        AP8121163
                        @NINJA TYGA supply new push rods for the rear sets, as there is a slight difference in construction.
                        Mine was a direct fitment and they look the same as your photo. So not sure what's going on here.
                          pedrobatista10
                          @NINJA the 7 from tyga set doesnt fit on the original item 10 from my aprilia. aprilia use m6 and tyga made with m8. thats the problem. but i will find out another way
                            N Offline
                            N Offline
                            @pedrobatista10 OK so are the linkage rods the same length? If the original one's used a 6mm bolt and the new Tyga one's use an 8mm bolt, would that not mean that you will have to drill the fixing hole out to be 2mm larger? Or is there not enough metal there to do that???
                              pedrobatista10
                              @NINJA thats what i will need to do! Not fitting because 2mm difference
                                N Offline
                                N Offline
                                @pedrobatista10 So the rods are the same length, it's just the different size bolts which are the problem???
                                  pedrobatista10
                                    pedrobatista10
                                    @Calum hey, this works on my bike, right? kickstarter
                                    http://www.wendelmotorraeder.de/kick-start-lever_ap0248365-p-3021127.html?ref=expl
                                      @pedrobatista10 Right but you need the rest of the components. Which can be quite costly.
                                      It is actually cheaper to just grab the whole engine, take the parts you need. Sell the rest.
                                        pedrobatista10
                                        can you tell me which more parts i will need? i cant find engine with kick anywere
                                          @pedrobatista10 You need it all. Have a look at the parts diagram.
