  3. Other
  4. Aprilia RS125 2010 Spain's no.1
226 Posts 7 Posters 116.3k Views 1 Watching
  • pedrobatista10P
    pedrobatista10P
    pedrobatista10
    @Calum @NINJA
    this part on yellow, dont fit. too big one of the sides.
      How long?
      It is adjustable, the two rods can be tied in, and the anchorage on the gear shaft lever can be manoeuvred
      • pedrobatista10P
        pedrobatista10P
        pedrobatista10
        @Calum im not explaining very well, sorry. its not long. problem is big size, just dont fit that tyga part. tyga part is bigger then the side it fit on the engine.
        i dont know if i explained right.
        maybe @DanRacing can help me explaining.
          @pedrobatista10 I would contact the supplier ASAP and get their advice dude. Normally you have 14 days to return stuff, so the sooner the better really. 😉
          • pedrobatista10P
            pedrobatista10P
            pedrobatista10
            @NINJA this part AP8121163 from tyga rear kit, doesnt fit on LEFT BALL JOINT M6 from motor.
            can you guys understand what im saying? i hope i explained well.
            anyways on tyga website they have for sale separately 2 different replacement link rod sizes.
            1- TYGA STEP KIT REPLACEMENT LINK ROD, 238MM ------- Uses M8x1.25 thread in one end and M8x1.25 L/H thread in the other. 238mm in length.
            2- TYGA STEP KIT REPLACEMENT LINK ROD, 110MM ------- Uses M6x1 thread in one end and M6x1 L/H thread in the other.
            maybe my tyga rear kit come with m8, thats why dont fit on the original m6 from my bike.
              Yeah, we would buy from different Stockists, I got mine from JapPartsUK.
              A picture says a thousand words, well worth just throwing up a photo.
                Looks like mine from the photo above.
                  @pedrobatista10 said in Aprilia RS125 2010 Spain's no.1:
                  AP8121163
                  You're talking about part No#7 in this pic I take it???
                  https://www.fowlersparts.co.uk/parts/5693151/rs-125-122cc-rs-125-122cc-rs-125-122cc-chassis-number-prefix-zd4mp0-zd4mpa-1996-1998-rs-125-122cc-chassis-number-prefix-zd4mp0-z/engine
                  Do Tyga make kits for different versions of the RS? Perhaps the parts you have on your bike are not the originals???
                    AP8121163
                    @NINJA TYGA supply new push rods for the rear sets, as there is a slight difference in construction.
                    Mine was a direct fitment and they look the same as your photo. So not sure what's going on here.
                    • pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      @NINJA the 7 from tyga set doesnt fit on the original item 10 from my aprilia. aprilia use m6 and tyga made with m8. thats the problem. but i will find out another way
                        @pedrobatista10 OK so are the linkage rods the same length? If the original one's used a 6mm bolt and the new Tyga one's use an 8mm bolt, would that not mean that you will have to drill the fixing hole out to be 2mm larger? Or is there not enough metal there to do that???
                        • pedrobatista10P
                          pedrobatista10P
                          pedrobatista10
                          @NINJA thats what i will need to do! Not fitting because 2mm difference
                            @pedrobatista10 So the rods are the same length, it's just the different size bolts which are the problem???
                            • pedrobatista10P
                              pedrobatista10P
                              pedrobatista10
                              • pedrobatista10P
                                pedrobatista10P
                                pedrobatista10
                                @Calum hey, this works on my bike, right? kickstarter
                                http://www.wendelmotorraeder.de/kick-start-lever_ap0248365-p-3021127.html?ref=expl
                                  @pedrobatista10 Right but you need the rest of the components. Which can be quite costly.
                                  It is actually cheaper to just grab the whole engine, take the parts you need. Sell the rest.
                                  • pedrobatista10P
                                    pedrobatista10P
                                    pedrobatista10
                                    can you tell me which more parts i will need? i cant find engine with kick anywere
                                      @pedrobatista10 You need it all. Have a look at the parts diagram.
                                      • pedrobatista10P
                                        pedrobatista10P
                                        pedrobatista10
                                        @Calum now i get your point, to buy a new engine :face_with_tears_of_joy: :face_with_tears_of_joy:
                                          @pedrobatista10 Although the RS and MX/SX 125's share the same Rotax 122 engine, the RS has an electric start whereas the MX/SX has a kick start. You can convert the RS to a kickstart, but you will need a lot of parts like flywheel, kickstart assembly, clutch case, starter motor blank off etc. However the biggest problem is you will either have to modify or most likely totally remove the whole left side fairings, in order to kick start the engine. You would be better off just sticking with the electric start and look at other ways to save a bit of weight, if that is your goal? Look at Titanium bolts, Lithium ion battery, carbon products or just go the old fashioned way by just removing unwanted stuff. 😉
