  4. Left side leak
Left side leak
5 Posts 3 Posters 651 Views
  • jakeyboyJ Offline
    jakeyboyJ Offline
    jakeyboy
    wrote on last edited by jakeyboy
    Oil coming from the left crank case side / sprocket. Any idea why this is happening? Think it’s a seal gone..
    https://m.imgur.com/VjwNJu4
      Easy fx, can be done with engine in the bike, So no dramas there. Change the seal and see how you get on.
      There is also th neutral swtich there which it might be leaking from also.
      jakeyboyJ 1 Reply Last reply
        jakeyboyJ Offline
        jakeyboyJ Offline
        jakeyboy
        @Calum lovely mate, thanks. What is the seal called do you know by any chance? Final drive seal?
          Sprocket seal, can be bought from PJME's site.
            NottsbikerN Offline
            NottsbikerN Offline
            @Calum isn't there a metal spacer as well? They can wear too if fitted and leak around the seal
