  3. Suspension
  4. Yamaha Arm Relay | Rear Arm Help!!!
8 Posts 3 Posters 1.7k Views
  • T
    T
    Taran
    wrote on last edited by Taran
    Hello,
    I have completely stripped my Yamaha DT125 X down to frame. I need advice on how to remove the link between the rear arm and frame. the bolt spins around & the arm moves freely. I have tried everything, I have soaked it in ac-90 over night, heated it and used a drift to force it out. Nothing seems to move it. Can somebody please help?
    • M
      M
      mhbikesnbits
      Get some heat on it and give a good tap with a bar it will come out
        So common this.
        You will need to just use lots of penetration fluid, heat and time and patience.
        T 2 Replies Last reply
          So common this.
          T
          T
          Taran
          Thank you both for the advice. I tried heat and a good tap, but no luck. I ended up cutting it off with an angle grinder. I have another one off a DT125x
            So common this.
            T
            T
            Taran
            @Calum Hi Calum, off topic. I was reading the Athena 170 thread and you mentioned that you would recommend the Zeeltronics. I have been looking into the PCDI-10VT, Would you recommend using the PCDI-10VT on a stock engine?
              Yes I would
              • T
                T
                Taran
                Hello, I have had a re-bore to 57mm (PJME) and I have a full arrow exhaust. The carburettor is stock and is up jetted.(RRP Coventry) When I bought the bike a green/black wire has been cut and is connected to the frame via the radiator mounting bolt hole. I have had the bike dynoed (RRP Coventry) and on the power run it archived 23 WHP, ( I can show you the dyno printouts ) will the PCDI-10VT increase the BHP?
                  A little bit off topic...but yes/no.
                  It may do, but what you'll really notice is the spread of power across the rev range.
