  3. Carburetor
  4. Standard jet size
Standard jet size
5 Posts 3 Posters 2.9k Views
  • Haako SmithH
    Haako SmithH
    Haako Smith
    What is the standard carb siede for a Yamaha dt 125 R?
      For the newer bikes it uses a 210 main jet. Or a 240 for the slightly older flat slide models.
      Haako SmithH 1 Reply Last reply
        Haako SmithH
        Haako SmithH
        Haako Smith
        @Calum Are you sure it uses 210 for original 28mm carb. IT seems a bit high dont IT?
        Glynn123G 1 Reply Last reply
        • Haako SmithH Haako Smith
          Glynn123G
          Glynn123G
          Glynn123
          @Haako-Smith Mikuni jet sizes differ to Keihn etc and flow differently, 210-240 main jet is correct on the standard flat slide 28mm
          • Glynn123G Glynn123
            Haako SmithH
            Haako SmithH
            Haako Smith
            @Glynn123 oh ok. That makes more sence.do you know what the differnece is? I am now running 146 main jet in a koso 32mm carb, but when i rev it at max it wont go over 8k in rpm.
