  3. Why does it do this?
7 Posts 3 Posters 472 Views
  • V Offline
    V Offline
    valtteri
    I just got my dt running and when dricing it just stops at very low rpms it has a giannelli pipe 28 mikuni with 260(main) 20(pilot) jets and ypvs servo is in use and a rebored cylinder to like 57.5mm. And the bike is restricted also the gren nd black wire is touching ground. So what could be the problem heres a video
    https://youtu.be/yx0jJ8STNx4
    V markus.wM 2 Replies Last reply
    • V valtteri
      V Offline
      V Offline
      valtteri
      Im gonna look if theres any air leaks and also gonna check if the ypvs works
      • ChallengerC Offline
        ChallengerC Offline
        Challenger
        If it sounds like this
        https://www.youtube.com/watch?v=90BbYwkOnFs
        then its an electronic cut-out rpm
        V 1 Reply Last reply
        • ChallengerC Challenger
          V Offline
          V Offline
          valtteri
          @Challenger yes well have you figured it out how to get it away?
          ChallengerC 1 Reply Last reply
          • V valtteri
            ChallengerC Offline
            ChallengerC Offline
            Challenger
            @valtteri alt text
            I installed this wire, its somewhere in the middle of the bike(under the seat) and the cut-out was gone. I dont know if it will help you, but I had 3RM-00 CDI and it was the older style of a DT but this little mod fixed it. You might have a different wiring loom since you have a newer style of a DT, but Im just posting here what helped me with getting rid of this problem. Anyway there is a solution to that problem.
            • V valtteri
              markus.wM Offline
              markus.wM Offline
              @valtteri sounds very similar to problem I had with my Old 89 dtr and that was the spark plug breaking down. Revved fine at standstill it only happened under load iirc. I may be wrong but it's quite a simple test to swap the plug. Best of luck to you.
                V Offline
                V Offline
                valtteri
                @markus-w thanks
