  4. The worst dt engine on ebay
53 Posts 6 Posters 10.0k Views 1 Watching
    Engine came up pretty well it's probably where I'll leave it cosmetically for now probably move on to getting my ignition sorted
    @declan £100???
      @declan £100???
      @NINJA technically 130 but I had to pay delivery from isle of wight so ended up 170 the only reason I got it was I had a dtx stator and case lying around and I had a good feeling that the engine was good underneath the crust so far I was right
        @declan Sounds like a good deal then. 😉
          @NINJA yeah but of a gamble now that i think of it but I wanted a project engine now I got it so I'm happy
            @declan You've improved it already, so it will only get better from here on in. 😉
              @NINJA thank you a fresh paint job is in the works what's been keeping you busy?
                @declan I'm currently building a new PC, but I will be working on my bike again soon, as my back has improved. I would have started earlier if it wasn't for me nearly chopping the end of my middle finger off a couple of weeks ago. 😞 😠 😠
                  @NINJA not ideal is it 😁 what's your pc for gaming?
                    @declan Yep gaming & general use
                      @NINJA nice well I not long ago got my first pc so message me on Facebook when it's done
                        @NINJA I literally bought an i9 9900ks upon release, it's just been sat in the loft doing nothing. Finally bought the motherboard, ram and psu this month. The pump I bought back September has been discontinued so now I have to buy two new ones if I want the PC to match.
                        Dayum, when did motherboards get so expensive, £550 for the motherboard! It was half that price when I last built one!
                          @Calum lol I think my motherboard is 70 new
                            @declan Just a single pump, bearing in mind I need two. £150
                              @Calum bet I'd still outlast you on Minecraft though 😂
                                I don't play games.
                                  I don't play games.
                                  @Calum see got ya beat already
                                    Do I need to ground the stator for it to produce power I'm testing the wires with just the stator on the engine with flywheel etc but not getting a reading
                                      Well it's potential difference. So if there is no reference to ground then there is no difference.
                                        The manual says test the stator resistance on x100 but my multimeter doesn't have that setting will 2000ohms Do? I wasn't able to get any signs of life off it yesterday
                                          I'm not sure if it's my flywheel that's the issue the flywheel for my stator is different to the one on the engine the one that came with the stator has big magnets that you can screw off where as the one on the bike is your normal dtre flywheel
