  3. Other
  4. CB750 scrambler project
139 Posts 11 Posters 68.0k Views 2 Watching
  • Louis-DT-WRL Offline
    Finally got the exhaust done.
    A few final checks and some cosmetic parts then it's show time.
    I did a patina finish to make it rustic... Showing the nickle plate under.
    Crash bars on.. only really for a more beefy look.
    Can't wait to hear it ๐Ÿ˜Š
    Definitely need to get some outside pics. The yellow walls is very distracting ๐Ÿ˜‚.
    • Louis-DT-WRL Louis-DT-WR
      Nearly show timing ๐Ÿ˜‚ 1st start up attempts coming soon.
      Tank now decorated.
      • S Offline
        Congrats! Itโ€™s nice to see someone doing their own thing! Nearly every ride Iโ€™ve ever had has been a butchers tripe mix of a thing. Mostly through necessity though! ๐Ÿ™„
        Iโ€™d really love to do a street tracker out of an old Honda CB 200 twin. Nice & lite yet revvy & torquey enough. Think of Girl with the dragon tattoos bike with attitude โ˜ ๏ธ
        They arenโ€™t easy to find anymore though...
          @SpookDog you could do what I did and buy a frame and build it up
            I'm not very familiar with this bike or twin terminal coils.
            Bike won't start, I believe it's electrical problem.
            No spark.
            The CDI I bought might be the problem.
            On the coil it has 2 electrical connectors (both +) and earth's to chassis.
            Ignition on and kill switch to run the voltage on 1 terminal (yellow and blue wire) to both coils has 12v.
            But there nothing on the other 2 black / white wires. Not even when cranking over.
            Surely there should be 12v to both terminals?
              Depends where you are measuring from. The coils job is to take the 12V DC and step it up to 20KV. So you measuring at 12V is outside the scopes range.
              12V isn't enough to jump the spark plug gap.
              Measuring Coils is usually done through impedance test on the primary to secondary, secondary to spark plug cap. Should fall within the tolerances outlined by the manufacturer.
                  Its a wasted spark system btw
                    @Calum thanks, I'm pretty sure both coils are bad. No resistance at all between power/trigger and the caps.
                    They were second hand, came with the loom.
                    12.8 volts on the looks power connectors.
                    New coils, leads and caps on order ๐Ÿคž
                    I
                    • S Offline
                      Wasted spark is when they both spark at top dead centre?
                      Have you not gotten any old coil off of another bike? Even a single one that you can get to spark? It would at least prove the rest of the circuit was on par...
                        @SpookDog yes wasted spark system is that.
                        I've ordered new coils as the primary has 3 ohms which is fine but secondary resistance has no resistance at all. On both. This is 1 fault. I'll have to see if there is others.
                        They are very old and probably corroded inside
                          This is the confusion I have , electrics are not my strongest point.
                          The manual says the yellow/blue wire goes at the top connector on both coils...
                          The coils are not handed so the green terminal is at the top on one side and black at the bottom when installed.
                          That's a what's confusing me ๐Ÿค”
                          I'm still waiting for the new plug caps to try.
                          I'm also not sure if I need to loop the sidestand indicator light as I removed it... I'm pretty sure it just piggybacks
                          • S Offline
                            If itโ€™s connected to the ignition it could be the cause of your problem, specially if youโ€™re neutral lights not working...
                              @SpookDog alt text
                              Do you think that's the problem looking at this?
                              To me it looks like if the neutral light is on (which it is) it should start.
                                So it looks like according to the diagram that the G/W wire needs to be tied to Earth if you want to bypass the side stand switch. The Y/Bl wire can just be taped up. I.E. don't complete the circuit for that.
                                  @Calum I have the sidestand switch, all plugged in. Only the indicator light isn't connected. Does that affect it? Cheers.
                                  Also still confused on the wires to the green or black connectors on the coils.
                                    The light only needs to be there if the side stand is down by the looks of it.
                                      @Calum that's what I'm thinking but if in neutral then it shouldn't Matter ,?
                                      • S Offline
                                        I canโ€™t get my head round the diagram at the mo. There are a lot of differences from what I know. What about the diode (number 7) condition?
                                        I know that the live wires on the coils will only affect spark timing if wrong, they should still spark. So Iโ€™m guessing that the problem is with the side stand, neutral, cutout circuit somewhere, if thereโ€™s no spark still...
                                        Sorry I canโ€™t be more help at the moโ€™. Too many brewskies!๐Ÿคช
                                          @SpookDog yes it's a crappy diagram, I assume the second bulb is the neutral one.
                                          I've never had a diode go wrong on anything but might test it.
                                          I think it's the side stand ... I'll do more tests when the plug caps come.
                                          Thanks
