  3. Other
  4. CB750 scrambler project
139 Posts 11 Posters 73.5k Views 2 Watching
  • S
    If it’s connected to the ignition it could be the cause of your problem, specially if you’re neutral lights not working...
      Louis-DT-WRL
      Louis-DT-WRL
      @SpookDog alt text
      Do you think that's the problem looking at this?
      To me it looks like if the neutral light is on (which it is) it should start.
        So it looks like according to the diagram that the G/W wire needs to be tied to Earth if you want to bypass the side stand switch. The Y/Bl wire can just be taped up. I.E. don't complete the circuit for that.
          Louis-DT-WRL
          Louis-DT-WRL
          @Calum I have the sidestand switch, all plugged in. Only the indicator light isn't connected. Does that affect it? Cheers.
          Also still confused on the wires to the green or black connectors on the coils.
            The light only needs to be there if the side stand is down by the looks of it.
              Louis-DT-WRL
              Louis-DT-WRL
              @Calum that's what I'm thinking but if in neutral then it shouldn't Matter ,?
              • S
                I can’t get my head round the diagram at the mo. There are a lot of differences from what I know. What about the diode (number 7) condition?
                I know that the live wires on the coils will only affect spark timing if wrong, they should still spark. So I’m guessing that the problem is with the side stand, neutral, cutout circuit somewhere, if there’s no spark still...
                Sorry I can’t be more help at the mo’. Too many brewskies!🤪
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @SpookDog yes it's a crappy diagram, I assume the second bulb is the neutral one.
                  I've never had a diode go wrong on anything but might test it.
                  I think it's the side stand ... I'll do more tests when the plug caps come.
                  Thanks
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @SpookDog I think if I try to crank the engine over (on the starter motor) in gear but with the clutch switch pulled in... That would also prove if the silicon diode is faulty 🤔
                    • S
                      A diode only lets electric pass one way I think. I’d try a continuity/bulb test
                      • S
                        Yeah, it should only show continuity one way. Do a quick google for diode testing...
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @SpookDog thanks.. I tested the resistance and compared it to my spare one, seemed fine. I'm pretty sure it's the sidestand circuit....
                          • S
                            I recon it is as well. I’d connect the side stand and clutch switch stuff all up, put it in neutral and try it with the clutch pulled in.
                            With the coil connectors, I’d try one ‘one way’ and the other the ‘other way’ if that makes sense? One of them should spark. Once they are sparking it’s easy to figure out which is the outer banks and which is inner...
                            Good luck my amigo!
                            • S
                              a Diode is like a one way valve for electric. The live wire on the anode and earth on the cathode should have continuity (power flowing through). Reverse the wires and there should be none.
                              • S
                                One other thing! Are the coils making a good earth to the frame? I don’t mean the black &white killswitch wires. I mean where the metal bolts to the frame...
                                  Good luck my amigo!
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @SpookDog pulling my hair out,
                                  All the diode does looking at the diagram is. When the stand is down and the bike is in gear, it won't start unless the clutch is pulled in .... But surely is shouldn't allow the starter motor to operate as that alone can knock the bike off the stand,
                                  Also should the side stand light only come on when stand is down ( in gear )or all the time including neutral 🤔
                                  • S
                                    I don’t think it’d affect the starter. I think it’s just to stop you pulling away.
                                    I recon it should be on as long as the stand is down.
                                    How many fuses are there as well!
                                    Wish I was there to help. It’s difficult trying to diagnose hands off!...
                                    • S
                                      Trouble is it could be any one of these switches:
                                      Key Ignition
                                      Handlebar kill
                                      Sidestand
                                      Clutch
                                      Neutral
                                      Or these parts:
                                      Pulse generator/pickup
                                      Fuses
                                      Or just a break in a wire.
                                      I’d start off by checking fuses, then doing continuity checks on the switches, then the wires
                                      Check for volts at the coloured coil wires, volts at pick up while cranking the starter
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        I think I know the issue. The pulse generator had a load of oil in there. Doesn't put out 0.7v
                                        When I crank the engine I can feel pressure of air blow past the crank seal 😬 the crank seal itself might not be broken but the pressure bypasses it.
                                        I can't see this seal on fowler's diagrams
                                        All cylinders seem to have good compression so can think why the crankcase has so much pressure. Unless it's a blocked pcv.... Not sure if they have valves ....
                                        Lots of ball aches...
                                        I couldn't really test any of this before fitting the engine all together.
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          Damn, wtf.... Surely you shouldn't have an access window to the side of the crank (bottom of engine)
                                          https://i.imgur.com/7LrE6wS.gifv
                                          See the video
