  3. Other
  4. CB750 scrambler project
139 Posts 11 Posters 73.5k Views 2 Watching
    4 strokes always have air movement in the case/block, the pistons pumping up and down displace air. You can get over pressure from worn rings/ piston blow-by...
    You ain’t going mad, sanity is just a learning curve πŸ€ͺ
    Louis-DT-WRL
    Louis-DT-WRL
    @SpookDog I think actually how this works now
    Apparently the pulse generator is supposed to have oil in there (oil cooled)... Which is great because there is no oil seal on the crankshaft that can go wrong......
    If you remove the cover when it's on the side stand (the only Stand I have)lots of oil will pour out...
    Only a small amount of oil come out on the centre stand....
    The pulse generator seems to not put out enough voltage so I've ordered a new one.
    As I've done lots of tests it is is the pulse generator that I believe is the issue.
    There's also supposed to be a proper gasket for the cover which I've ordered
    The CBX 750 which is almost an identical engine have the oil filler cap on the left-hand side.
    As the cbx750 shares a lot of parts
    On my bike this has a cap saying "do not open"
    On the left casing (where the oil filler is on the CBX)
    if you open this when it's on the side stand oil will pour out as well..
    . I'm guessing at the CBX 750 at the side stand on the right hand side.
    • S
      I had a gsxr750 that was the same, oil cooled, 2 oil caps, total bitch to diagnose 😊
        Louis-DT-WRL
        Louis-DT-WRL
        @SpookDog it's not even mentioned in the manual about not removing the left-hand pulse generator cover on the sidestand πŸ€·β€β™‚οΈ
        • Louis-DT-WRL
          Louis-DT-WRL
          I have no idea when I use the shrug emoji it changes it to a girl and the gender symbol πŸ˜‚
          After further investigation... My cdi which was sold by a bike breaker written in white paint "cb750 1997" ... I cleaned off the paint carefully and the part number just about readable is
          MASG G
          571U
          Which is a cbr900!!!
          Whether or not that's a problem, I've got another one from another spares breaker with the correct part number for the cb750 sevenfifty
            Keep us posted! I'm itching to hear that you've cracked this!
              Louis-DT-WRL
              Louis-DT-WRL
              Same here. Should be beasty.
              I knew the electrics would be the hardest part.
              All lights and horn was easy.
              Starter circuit was ok.
              Just the ignition circuit 😁
              • S
                It WILL fire up with a new CDI, unfortunately online buying is a fukin shark feeding frenzy of a$$holΒ£s all caring about one thing. The amount of times I’ve been shafted on fleabay is unreal. Brought a headlight that came without the bulb holder or rubber, the bloke had the neck to tell me that I was confusing his with another listing, conveniently after his pics were down. The only reason I nodded was cause it was complete...
                Another bloke changed the listing twice while I was between messaging. Once to up the price Β£40 then to change from 3 wire to 5wire servo! Same listing number an all...
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @SpookDog I know the feeling. Many sellers have lots of similar items for sale but send the wrong ones.
                  The problem is I built this bike with parts from about 30 bikes... And no real way to test it will work together until I try
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    I've got sparks on the plugs.... Just need 1 more part before I start up.... πŸ’ͺ
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      She runs and runs beautiful!
                      I'll do a video when fully warmed up.
                      And not pouring rain.
                      It was screeching when I started it., Originally thought it was the starter, but when running it was awfully loud. I thought "here we go" something major.
                      I had a suspicion it was the generator....
                      Look what I found...
                      A tiny recess where a slightly bent fan blade was rubbing the cover.
                      Really easy fix and now sounds great!
                      • S
                        Congrats bud! I thought it be painless in the end...
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @SpookDog cheers , and thanks for following everyone. Some final cosmetic touches and possibly rejetting left to do πŸ’ͺ
                          Can't believe how fast and smoothly it revs up
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            Have a little listen 😝 ears are bleeding πŸ˜‚
                            https://youtu.be/3E1flO9j7BA
                            link text
                              Haha! Ruthless!
                              • Louis-DT-WRL Louis-DT-WR
                                @Louis-DT-WR BRAP BRAP BRAP, sounds beastly dude!!!
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @NINJA it is very beastly sounding if I say so😁 I didn't know what to expect. Definitely will wear ear defenders next time
                                    I know it's not the same, but my RS is too loud for prolonged use without ear plugs. My ears are literally ringing from the noise. I am a sensitive lad though.
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @Calum we all like a noisy exhaust until you ride a long journey with one, then it just gets annoying
                                        @Louis-DT-WR ive never been a fan of loud exhausts i prefer a good quality exhaust note
                                          @declan said in CB750 scrambler project:
                                          Agreed. I prefer quiet engines that make power. Turbo Flutter is a must.
                                          Now an eargasm superbike inline 4 that's a win.
                                          But I can't stand loud Hondas that make fack all power.
                                          Louis-DT-WRL DartyD 2 Replies Last reply
