  4. Ypvs servo motor
Ypvs servo motor
27 Posts 10 Posters 11.4k Views 1 Watching
    Hang on, hang on, hold up a minute...
    Are you telling me we could upgrade the servo motor to improve the servo’s responsiveness across the rpm range?
    Aye, I might have missed something but I can’t have been the only one to think it moves like it’s got arthritis
    A
    A
    Arild
    @Stevie-Wonder
    Thats my guess, but at the same time the bike doesnt jump from 4k to 10k in an instant, so i dont really think u need some ultra super dc torque monster electrical motor, i think its just fine with a normal one, or the original but just maybe with some new brushes which u can find on ebay
    • A Arild
      @Stevie-Wonder
      Stevie WonderS
      Stevie WonderS
      Stevie Wonder
      @Arild Yes I agree and it’s not that it’s doing a bad job, I just saw the way the servo shits the bed if you’re quick on the throttle above 7-8k rpm and thought hmm I wonder if that could be improved and what difference it’d make.
      Ps I’m in two mind about my own comment because in real life riding scenarios you should never be choppy with the throttle when riding a two stroke. All or nothing, it’s your responsibility to work the bike like an instrument to keep it singing in its sweet spot
      A 1 Reply Last reply
        A
        A
        Arild
        @Stevie-Wonder
        Yeah could probably be improved, could start by opening the motor u have urself and see how it looks, mine was the definition of shit the bed, it could most likely have a small refresh and work great, otherwise u can buy the same size motors but that have way more torque and rpm and i guess that is the important part for ypvs
        • G GeirA
          These motors are simple DC 385 motors and cost next to nothing from sites like AliExpress, Ebay and Amazon.
          Just Google "385 DC motor" and you will get a lot of hits. They usually come with different voltage and rpm-ratings. So buy a few and try which one works the best. It should also be fairly easy to work out the rpms too by doing some simple math.
          Please post which motor that worked best 🙂
          The YPVS is quite simple a servo motor that works just like model airplane servos. As far as I know, the YPVS use 12V supply voltage and 4,9V PWM pulse signal.
          G
          G
          GeirA
          @GeirA said in Ypvs servo motor:
          I have researched a bit more and found that I have mistaken the pulse signal for being PWM. It's probably the rpm signal, not PWM.
          • A Arild
            @GeirA
            Hey yeah, my first instinct was to go on ebay and aliexpress, then i remembered that sweden has fees from taking packages outside of europe, so every 1 quid dc motor would end up around 10 quid each because of customs etc, and not to mention the fact that it takes a long time for them to arrive
            I dont know how dc motors work, i would think that the most important part is the torque it produces, but im not too sure
            But thanks for letting me know that its called a 835 dc motor specifically, easier to find what im searching for now
            G
            G
            GeirA
            @Arild Isn't Sweden an EU-country? I live in Norway and there are virtually no extra fees ordering from China or other countries, at least when ordering stuff worth less than 300NOK (about £25). And Norway isn't even EU. That's strange.
            But you could try to search for hobby stores in Sweden at the web. Some stores might have a 385 motor. As I mentioned, it's an ordinary hobby motor.
            • S
              @Stevie-Wonder
              I’m sure you’re thinking of it stationary, when power isn’t really an issue. When you’re in most gears and accelerating it moves fast enough. I understand where you’re thinking is coming from though...
              • G GeirA
                A
                A
                Arild
                @GeirA
                Idk why sweden has done it they way they have but basically postnord, which takes care of the packages as soon as they enter sweden, take 70kr just to handle the package, and then they also take 10% of what the package was worth and add it onto the 70kr, so even the smallest things end up expensive, except if u order from wish, since wish takes care of the fees but shipping from wish is always around 70kr anyway, so there is no real good way of buyinf chinese things into sweden anymore
                • Louis-DT-WRL
                  Louis-DT-WRL
                  The way the guy in the video has done it would make the valve not operate correctly.
                  The pulley on the motor is not the same size as the plastic pulley on the cylinder.... It's changed the rotary parameter and timing.
                  Also I'm pretty sure it would be running backwards as the servo is now facing the cylinder.
                  • Louis-DT-WRL Louis-DT-WR
                    A
                    A
                    Arild
                    @Louis-DT-WR
                    Yeah that would make sense, might be fixable with a zeeltronic though?
                      It may be possible with the zeel.
                      If it's running backwards then you'd need to invert the pulleys.
                      Then use the zeel to alter when it opens and closes, if necessary don't make it 100% open. It may still feel "off" and not give that YPVS feel.
                        A
                        A
                        Arild
                        Yeah,i wouldnt do it myself tho, he has another video where u can see the servo on the powervalve and it just looks out of place right on the cylinder
                          There are no improvements to be made mechanically here,
                          More importantly being able to adjust the PV duration and timing effective to your Cylinder and Exhaust setup over stock.
                            I was told, time spent fine tuning powervalve timings is worth its weight in gold.
                            In my opinion, this all depends on the usage.
                            For road racing, a finely tuned opening wouldn't net huge gains. Since once you are fully opened, you are likely to stay that way. I.E. does the Honda RS125 even have a powervalve? Or is it just chocked wide open.
                            MX a working powervalve is important, but there is always the gear below? I know people faff around with springs to get that powervalve open earlier/later but often it's just about shifting the timing.
                            I was told by a local technician at Yamaha that tuning the valves timing will net you decent gains. I was always too lazy to actually do any of this.
                            • C
                              C
                              Carl Kennedy
                              My servo do t seem to be getting any power it's not doing a cycle all the wires look good connections has me stopped myn is a 4 wore plug witha separate yellow wire it has me stupped
                              P 1 Reply Last reply
                              • C Carl Kennedy
                                P
                                P
                                Polnak88
                                @Carl-Kennedy
                                hello, I had the same problem. Found out that someone ripped out the mechanical gears out of it, you can try that. And if you happenned to have them, could you please tell me the dimentions of the gears? Thanks
