Engine bearings
Does anyone have list of dtr engine bearings sizes? Especially the 2 needle bearings sizes
I've always taken the old bearing along to a bearing supplier and got them to sort me out with the correct one/s
Make sure that you get the correct size and grade so that they not only fit but are up to the job required of them
@nottsbiker DTR has an odd size. They are on PJME but money can be saved if you go to SimplyBearings
Yes found that out to my dismay once - think they are 1mm narrower than the nearest commonly available bearing.
Why wont these casings go back together.....
