  3. Other
  4. DT125LC MK3 1986
DT125LC MK3 1986
11 Posts 5 Posters 4.9k Views
  • S Offline
    Stumpy125
    wrote on last edited by Stumpy125
    So after a long time looking and a trip up to Liverpool to see the bike. I had to give the bloke three hundred sheets a opportunity i couldn't say no to. After the long drive home here she is.
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0422_zpsyypp8enr.jpg
    It has been stripped for a farm bike, I intend to re-build and restore her to her full road legal status.
    Kettle on, work shop open and queue the music.
    After a good jet wash it started to appear to be in a sorry state
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0424_zps1vpooeo0.jpg
    It started becoming more apparent to me this bike has not been looked after or any general maintenance done. I proceeded to remove the engine from the frame and start the stripping down process. More damage became apparent fudged bolts, engine damage and parts just missing
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0440_zpsfdmeh8ud.jpg
    Next out came the clutch and all the running gear. i think someone has been in here before. But i don't think they knew the difference between a hammer or a screwdriver.
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0448_zpsllcbfvz1.jpg
    I have to admit the clutch basket and most of the gearing came out with no problems. with the generator and flywheel out, off came the head and piston no problem.
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0456_zpss2bqbb7e.jpg
    It was time to remove the bolts and split the engine.............
    Hang on there are only 5 bolts holding this thing together and they were fudged beyond belief, Get the drill out. drill and re tap lovely time for a brew and a think before i tackle that.
    Right done engine split and i have to admit it is very clean inside
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0474_zpscysqviwb.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0469_zpsirn09u3o.jpg
    Anyway out came all the gears and dogs with the selector drum all the oil seals which means it is time for cleaning
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0481_zpspumzdkae.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0489_zpsvz3fqbvs.jpg
    As you can see in the pictures the engine is now clean and all damage repaired. nearly time for paint just a little more prep.
    We have paint!
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0105_zpscgygmrs9.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0116_zps2eiabc27.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0528_zps4lz536ju.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0527_zpsokajt9ef.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0526_zpsbs6sl4ib.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0118_zpskyea9zru.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0109_zpsxi3ztxha.jpg
    http://i1174.photobucket.com/albums/r608/simonworkman/DSC_0106_zpsj5mrdip5.jpg
    This is it for now i have more but for now this is a start........
    If you can't fix it with a hammer, you have an electrical problem
    • MightymanM Offline
      MightymanM Offline
      I'm not actually able to see any of the images for some reason?
      EDIT: All sorted now!
        YEs mate. Looking grand.
        You will have one fine bike when this is done! Keep the updates rolling pal!
        • BurridgeB Offline
          BurridgeB Offline
          Burridge
          Read this yesterday but can see the pictures now! Your work is looking great so far mate, very smart! Good luck with the rest of the build and keep the updates coming
          • S Offline
            Stumpy125
            Cheers guys I'll keep the pics rolling in
            • Biker_123B Offline
              Biker_123B Offline
              Biker_123
              Great work so far!! 👍🏻
              Every problem has a solution
              • S Offline
                Stumpy125
                Right for some time i have been hunting for a rear mudguard for this bike. Cheapest i have found is around the £200 mark.......
                Today just purchased one for a staggering 99p + £5.00 postage
                Bargain i think
                Biker_123B 1 Reply Last reply
                • S Stumpy125
                  Bargain i think
                  Biker_123B Offline
                  Biker_123B Offline
                  Biker_123
                  @Stumpy125 That's definitely a bargain !!! Good find mate, now if only the rest of the fairings you need show up for a similar price youll be sorted :)
                  • Biker_123B Biker_123
                    Stumpy125
                    @Biker_123 I'll be laughing at that price if i find them
                      What was the condition though? Obviously 200 new.
                        Stumpy125
                        @Calum second hand slight damage but nothing that can't be sorted, also i can try to take a mold of it. Try and produce more.
