  4. How do you wire a stator/magneto?
3 Posts 2 Posters 714 Views
  • GoProKid95G Offline
    GoProKid95G Offline
    GoProKid95
    Hi all,
    I’ve identified my stator/magneto as dead. I’ve sourced a replacement unit, which has been removed from a working engine, however when it arrived the wiring is cut from the block connector.
    I’ve still got the original so am familiar where the wires need to go, however three of them are solid white, so could they go to any of the three pins?
    Thanks in advance,
    Tom!
    GoProKid95
    2006 DT125RE - SM Conversion
    • GoProKid95G GoProKid95
      Hi all,
      Thanks in advance,
      Tom!
      @goprokid95
      Can you not jus trace them back on the original? Remove and replace the outer sleeve if needed...
      GoProKid95G 1 Reply Last reply
        @goprokid95
        GoProKid95G Offline
        GoProKid95G Offline
        GoProKid95
        @spookdog Hi mate, the wiring is currently stripped right back on the replacement unit. I think I may have it sorta resolved now, gonna fit it tomorrow and see if it runs!
        GoProKid95
