  4. Question about 2 stroke throttle to rpm relation
19 Posts 4 Posters 8.6k Views
    @ramekenas firstly that oil pump doesn't leak into the engine or gearbox. Either put a pump on it or leave it alone.
    That carb is inferior to the standard carb get the original one back they are not expensive.
    Swingarm put the nut back on so that it is screwed on but slack. Then hit the nut with a copper mallet as to not damage the thread or nut and that shall release. Some wd berween the engine mounts may help.f
    R
    R
    ramekenas
    @Calum Thank you !
    Good to hear that the pump gap could not have wrecked the engine!!
    Which carb exactly should i be looking for? DellOrto VHSA 32ES , DellOrto VHSA 32GS?
    They are interchangable so all the rubber parts will fit them both , is that correct?
    I was hitting the bolt with a wooden spacer and hammer for quite a while didn't budge, have to try that with a copper sheet spacer.
    And since when do hammers cost 50euros ^^ didn't know copper hammers cost that much, wow!
    Thanks for the help!
    • AndyYamA
      AndyYamA
      AndyYam
      good photos. love the bit of wood to block the oil pump cable.
      the carb you need is a vhsa 32mm. i do have one for sale. if ypure interested i can get photos.
      agree with cal on the copper mallet. wd40 is good but a specific penetrating oil would probaby be better. screwfix were doing big cans of no nonsense for £3 recently. if you still cant get it shifted then a heat gun on the end might help break it free. just be careful of seals etc unless you plan to replace them anyway.
      swing arm rebuilds are costly though so only do if needed and remember to grease it all well and keep ut greased using the nipples.
      R 1 Reply Last reply
      • AndyYamA
        AndyYamA
        AndyYam
        also on the oil pump front. there are mixed views on their reliability but if rebuilt and the bike is looked after it makes it far more efficuent. i know a guy on the 350 ypvs forum who rebuilds them. im probably getting mine done on the dt engine im doing atm.
        • MightymanM
          I wonder on the opposite side of things if it's possible for the pump to fail and cause over oiling? A friend of mine says his DT keeps overheating and I reckon it could be too much oil if his coolant is fine.
          • MightymanM Mightyman
            @MIGHTYMAN Whilst it is true fuel cools the piston down, and throwing that ratio out will affect its heat.
            Over oiling will reduce friction in the engine, reducing temps.
            So not convinced on that idea.
            • MightymanM
              Too much oil though definetly makes heat.. I can't remember the exact explanation but it's something to do with the oil changing the octane levels? My 250 EXC seized when i stupidly put twice the oil ratio into a mix of petrol.
                @MIGHTYMAN Like I said, that's due to the dilution of petrol, not necessarily the addition of oil.
                For example, KTM EXC 250 Two Stroke.
                Pre mix oil and fuel, dilutes the petrol mixture.
                DT125R, with oil pump, adjust the oil pump to max settings and the fueling stays the same.
                That's in response to your friends over heating problem.
                Other possibilities are contaminents in the Coolant system reducing the specific heat capacity of the coolant, increases temps.
                • R
                  R
                  ramekenas
                  wrote on last edited by ramekenas
                  Well not much progress today, swingarm is still stuck in the bike ,but i managed to free it from the bolt itself now the swingarm can move without the bolt turning with it , it is stuck on the washers near the head of the bolt
                  according to this pictue, on one of those parts 7,9,5
                  Fixed a few wires and cleaned connectors on the wiring loom.
                  What do you guys do when the loom becomes stiff - every wire on mine has insuliaton like hard plastic?
                  • AndyYamA AndyYam
                    R
                    R
                    ramekenas
                    @AndyYam
                    How much would you want for the carb?
                    AndyYamA 1 Reply Last reply
                      7 is not a washer it's a dust seal.
                      • R ramekenas
                        @AndyYam
                        AndyYamA
                        AndyYamA
                        AndyYam
                        @ramekenas £60 delivered.
                        So what is the problem with the swing arm? I'm confused as to how its stuck? the pivot bolt is out now?
                        Diesel, coca cola or penetrating oil and then a heat gun is still my best advice.
                        • AndyYamA AndyYam
                          R
                          R
                          ramekenas
                          @AndyYam
                          Well i tried to take the bolt out for 4 days and nothing happened ,only on day 3 did hear the bearings crunching in there , it is rusted solid and a multiple ton press is required or something like that, i even took a rotary hammer and tried to hammer it out to no avail. The oil fittings in the swingarm look like they never been used you can't see shiny metal there at all, so out of pure despair put the bloody thing back together and filtered the oil and it stopped whining , i have a feeling its clutch plates + dirty oil.
                          I changed the oil at the beginning of this season but it was grey-ish all ready looks like the gearbox won't last to long. I thought about it and decided if i can make it running for the rest of this season i will so i could clean up the garage get some tools some books/manuals, and do everything properly during the winter because i need the bike to repair the bike catch 22.
