  4. DT125R 2001 restoration
dtr helpelectricsspark
16 Posts 4 Posters 3.7k Views
  • K ksk.04
    @calum okay, thanks!
    I'll start testing for continuity on every wire and see if I find something
    @ksk-04 Won't just be continuity. The side stand switch causes problems if it's not wired in correctly. A quick search on this site should show countless people falling into that trap.
    My advice stands, get yourself a Haynes manual and systematically go through the loom putting it back to factory. If you don't it will be very hard to fault diagnose.
    K 1 Reply Last reply
      K
      K
      ksk.04
      @calum is it supposed to be a relay or something for the side stand switch next to the neutral switch? I have some wires hanging loose there with no plug
      • NottsbikerN
        NottsbikerN
        If the loom is that bad personally I'd just get a new one if they are still available.
        The wires on old looms can become quite brittle and often the wires / connectors etc get full of that green corrosion
        Obviously though you need the money for a loom 😉
        • NottsbikerN Nottsbiker
          K
          K
          ksk.04
          @nottsbiker problem is that i cant find one
          • NottsbikerN
            NottsbikerN
            Have you tried Fowlers, CMSNL, Ebay France/Germany/Italy etc? 😉
              @nottsbiker Can't see looms being cheap 😮
                @calum Hhhmmm...
                Not bad actually.
                https://www.ebay.co.uk/itm/313667092027?hash=item490803fe3b:g:k3MAAOSwyFhhOS68
                https://www.fowlersparts.co.uk/parts/view/3RM-82590-00
                £130~ Approx which is really good!
                NottsbikerN K 2 Replies Last reply
                  @calum Hhhmmm...
                  Not bad actually.
                  NottsbikerN
                  NottsbikerN
                  @calum for the cost I'd say its worth it tbh
                    @calum Hhhmmm...
                    Not bad actually.
                    K
                    K
                    ksk.04
                    @calum Will that fit my dt?
                    According to cmsnl.com 3RM8259040 is the correct one for my bike, the one you sent is 3RM-82590-00-00
                    CalumC S 2 Replies Last reply
                    • K ksk.04
                      @ksk-04 Probably not, not sure what was changed between the years. Again, the Haynes manual will know.
                      • K ksk.04
                        @ksk-04
                        That sounds like the right one...
                        Check where the wires come out above the gear change lever. The magnetic pickup wires can become bare where they pass through the rubber...
                        You should have a good strong bright continues spark when you give it a good kick over. Not just one or two weak sparks. Try getting an irridium plug for a stronger spark...
